Hello!
No, if preselection is on, then working with assemblies is extreme slow. The mouse trigges the calculating on the left bottom on the screen (all 4 CPU are working, the GPU is laughting). Only when the mouse in not over an element of the assembly, then is fluent when the preselection is on. Also a have the feeling, when an element A was made before element B, than the calculation of the coodrinates on the left corner is a very little bit faster from A than B. I hope you understand what i mean. I can made a webm on the (right) thread.
If the preselection is off, FreeCAD is fast. It is nearly intenpended of the deviation (tesselation).
But that is off topic, but thank you for your interest.
Sorry for bad english, and thank folks for your help.
Greetings
user
(solved) 0.18.15248 do not open files correct
