[feature request] sketcher make
Jee-Bee
Postby Jee-Bee » Fri Jan 11, 2019 8:59 am
abdullah wrote:
Thu Jan 10, 2019 3:53 pm
ping
I have a feature request for dimensioning of the thickness of two concentric circles.
I now need a workaround for this(see attachment) that work. Better would be if it works directly out of the box. see also example in creo
Re: [feature request] sketcher make
Postby chrisb » Fri Jan 11, 2019 9:25 am
This seems to be a reasonable feature. The workaround is not too complicated, but looking funny on arcs, if the construction line doesn't touch the arcs:
Bildschirmfoto 2019-01-11 um 10.24.28.png (12.11 KiB) Viewed 404 times
abdullah
Postby abdullah » Fri Jan 11, 2019 1:19 pm
Isn't this offset curves?
They are scheduled for v.19:
issue #3668
easyw-fc
Postby easyw-fc » Fri Jan 11, 2019 1:30 pm
issue #3668
that would be wonderful!
like creating a sketch as an offset path from an enclosure outline automatically ;)
Jee-Bee
Postby Jee-Bee » Fri Jan 11, 2019 1:36 pm
Yes and no... for small thinks it is as fast to create 2 circles as create circle with offset
abdullah
Postby abdullah » Fri Jan 11, 2019 3:07 pm
Ah! I did not realise that you were actually creating both circles in creo.
So you are looking for a new constraint "difference between radius".
Although it may seem as a simple thing, it is really not. It is also not generic, as it would only work for circles, i.e. it requires an implementation per each shape to be supported. Additionally, I think there are geometric shapes were an offset curve is not the same type of curve as the original one, the offset of an ellipse is not an ellipse if I remember correctly.
Unless I am understanding it really bad, this should go with a single click one the offset curve functionality is in.
Jee-Bee
Postby Jee-Bee » Fri Jan 11, 2019 5:31 pm
I No not per se. Just an angular or linear dimension used on both circles. In FC it gives now an error "no circular edges"
Sorry i don't know the background but i guess if two circular shapes (so no offsets) it should be more easy to distingish than a circle and his offset.
abdullah
Postby abdullah » Fri Jan 11, 2019 7:25 pm
Like two radius constraints, the second having as datum an expression "radious1+thickness"?
I am not sure how offset curves will look like yet. An offset curve is kind of a geometry and a constraint with respect to another geometry. I am still to think the actual implementation that work best with OCCT and the solver.
Jee-Bee
Postby Jee-Bee » Fri Jan 11, 2019 10:12 pm
No i think you understand me wrong. I want the result of what you named "difference between radius", but i don't like to heave a new constraint. I prefer to do more with less. all different buttons create just clutter. how to handle this (from user point of view) is a different topic!
But if for now a "difference between radius" constraint is needed i accept that :D
I think in CREO it just create the same type of feature when creating an offset. But it creates bsplines curves from geometry(except maybe straight lines). As i said i have no clue about OCCT but i would guess that it knows what type of line you use for offset (straight line, arc or bspline). So i leave that to you ;)
NormandC
Postby NormandC » Sun Jan 13, 2019 11:01 pm
@abdullah
In most CAD software's sketcher functionality, you can constrain to circles and arc's cardinal points (north/south/east/west). So in the case shown by Jee-Bee, it's just a simple horizontal distance constraint between the east quadrant of both circles.
Not so simple to implement in the Sketcher, I guess. This is similar to people who regularly ask for a way to constrain to a line's midpoint. None exists in the Sketcher.
BTW Yorik managed it in Draft with his Snap tools (as well as snapping to cardinal points).
