Failed to validate broken face....
KV90
Postby KV90 » Tue Jan 22, 2019 1:09 am
Can't understand why my sketch has a "broken face" not new to this software but new to drawing something more complex like such it is really throwing me for a loop.
BumperTopRev2_IWIN.FCStd
(7.45 KiB) Downloaded 4 times
Re: Failed to validate broken face....
Postby chrisb » Tue Jan 22, 2019 6:19 am
Hi KV90, welcome to the forum.
First thing to do in such a case is to make the sketch visible and use the "Validate sketch" tool in Sketcher (or PartDesign). And here we go finding two missing coincidences!
If you fix them - either automatically in the tool or manually - still reports a much more severe problem in report view. BTW: this error was there before fixing the coincidences.
App::Document::recompute(): cyclic dependency detected
Next step in the investigation is the Std DependencyGraph, which shows
Bildschirmfoto 2019-01-22 um 07.11.25.png (21.78 KiB) Viewed 115 times
This should never have happened. So we are very much interested how you got there!
To fix it make the Origin in the body visible, select XY plane and attach the sketch to it (icon: blue cube with a sketch at the side). Either leave the attachment mode as is or use "Flat face(recommended)".
The sketch still shows the error, but a recompute fixes it.
Using black color for solids is not advised before your model is finished, because the black color is used as an indicator for invalid solids.
Postby chrisb » Sun Feb 03, 2019 3:12 am
Moved to help forum.
