Part-wb extrude with taper angle, bug or feature?
freecad-heini-1
Postby freecad-heini-1 » Wed Jan 23, 2019 11:47 am
please create a sketch with a circle 2mm diameter on xz-plane.
Extrude it along y axis 2mm with taper angle 4°.
This is my result:
Is it a bug or a feature?
Best regards
Wilfried
OS: Ubuntu 16.04.5 LTS
Version: 0.18.15650 (Git)
Hash: c9b4f4ba6779c9ccddb69fba57eee1b5acfd4083
Python version: 2.7.12
herbk
Re: Part-wb extrude with taper angle, bug or feature?
Postby herbk » Wed Jan 23, 2019 12:02 pm
Hi Wilfried,
it works with other Diameters and angles to. ;)
Seams that nobody had made a cylinder with an taper angle, which is not placed at xy plane till now... :lol:
Gruß Herbert
freecad-heini-1
Postby freecad-heini-1 » Wed Jan 23, 2019 12:12 pm
Hi Wilfried,
YZ same problem.
part-wb_extrude_taper-angle.FCStd
(10.99 KiB) Downloaded 5 times
Site Admin
Postby wmayer » Thu Jan 24, 2019 6:23 pm
freecad-heini-1 wrote:If you extrude a sketch with a taper angle in xy plane, it works fine.
But if you extrude in xz and yz direction, it's wrong.
It does not even work correctly when the sketch is in xy plane. Just observe the height of the drafted object: it will be 20 instead of 10.
The actual problem seems to be the OCCT class BRepOffsetAPI_MakeOffset which has a very strange behaviour. If the underlying shape to be offset has a placement applied then this class applies it a second time on the output shape.
Example:
wire1=App.ActiveDocument.Sketch.Shape # the xy sketch
wire1.Placement
# empty placement
wire2=wire1.makeOffset2D(-0.5)
Part.show(wire2)
# wire2 is ok
wire3=wire1.copy()
wire3.Placement.Base.z=10
wire3.Placement
# wire has been moved along z axis
Part.show(wire3)
wire4=wire3.makeOffset2D(-0.5)
Part.show(wire4)
# wire4 again has been moved along z which is not OK
Site Admin
Postby wmayer » Thu Jan 24, 2019 10:05 pm
It looks like that the problem only occurs if the basis wire consists of a single edge. If you make a sketch with two half-circles then the extrusion works independent from the sketch plane.
Postby chrisb » Thu Jan 24, 2019 11:53 pm
Now as you mention this: I think we had it before and DeepSOIC has investigated it. There might even be a bugtracker issue.
freecad-heini-1
Postby freecad-heini-1 » Fri Jan 25, 2019 6:48 am
Hi Werner,
thank you so much for your ongoing great work here. Two half circle, that's a hack I can work with.
Best regards
Wilfried
Site Admin
Postby wmayer » Fri Jan 25, 2019 9:10 am
You don't need to. With git commit 4079c9603fe it should work out of the box now.
jmaustpc
Postby jmaustpc » Tue Jan 29, 2019 1:10 pm
Your getting a bit slow Werner....a whole hour and 5 minutes to fix and report a bug! You must need more caffeine, come over to my place mate and I'll make you a coffee. :D
Actually I am feeling generous, I'll take you into town to a nice caffee and buy you one, it's only about a 60km drive. :D
