FreeCAD Trails Workbench (Transportation and Geomatics)
HakanSeven12
Post by HakanSeven12 »
Hi everyone. I'm a Geomatics Engineer and Joel_graff is a Transportation Engineer. We decide to create a workbench for our own needs. So this workbench is being developed to provide functionality specific to Transportation and Geomatics engineering.
I already did what I want at the beginning. So I decided to open this topic. If you have any idea, feature request or something else, I want to listen it and implement it to workbench.
You can fallow our progress from bellow links:
Patreon: Hakan Seven on Patreon
Twitter: Hakan Seven on Twitter
OSArch Community: FreeCAD Trails Workbench on OSArch Community
GitHub: FreeCAD Trails Workbench on GitHub
Features:
* Geodata Tools
* Import Survey Data Files
* Export Point Groups to File
* Create Surface
* Edit Surface
* Create Regions
* Create Sections
* Calculate Volume Areas
* Create Volume Tables
* Create Building Pads
* Import Alignment LandXML files.
You can see what Trails can do from bellow pictures:
Last edited by HakanSeven12 on Sun Jul 04, 2021 7:42 pm, edited 53 times in total.
microelly2
Re: Geomatic Workbench
Post by microelly2 »
There are a lot of different methods to import geodata in my geodata workbench.
see
https://forum.freecadweb.org/viewtopic.php?f=8&t=6973
you can install (and contribute geodat wb) form addon manager.
Post by Kunda1 »
microelly2 wrote: Fri Feb 22, 2019 9:12 am There are a lot of different mehtods to impport geodata in my geodata workbench.
see
@microelly2 That's cool, but what about the geodata not being py3 ready? doesn't that present an issue for 0.18/0.19dev users ?
HakanSeven12
see
There are a lots of type of geodata files. I can easily select data columns and automaticly import my points in to a group. I continue to working on it. :)
Joel_graff
Post by Joel_graff »
Kunda1 wrote: Fri Feb 22, 2019 12:08 pm @microelly2 That's cool, but what about the geodata not being py3 ready? doesn't that present an issue for 0.18/0.19dev users ?
I don't mind helping out porting code, if microelly wants any. I haven't tested the wb, but it does load for me - I just get the warning about an improper print statement. Of course, there could be dependency issues...
Post by Kunda1 »
Joel_graff wrote: Fri Feb 22, 2019 2:24 pm I don't mind helping out porting code, if microelly wants any. I haven't tested the wb, but it does load for me - I just get the warning about an improper print statement. Of course, there could be dependency issues...
https://github.com/microelly2/geodata/issues/12
Joel_graff
Forked geodata and am working on fixing the print statement syntax. There's a lot of them...
Joel_graff
https://github.com/microelly2/geodata/pull/15
First pull request. Fixes not-equal-to and print statement errors. Also discovered there are some significant dependencies that are broken in the Python2 to Python3 transition. Will keep picking away at it and sending pull requests. :)
Joel_graff
Just finished adding importlib.reload imports and fixing urllib2 (which was replaced in Python3 with urllib.request).
However, when I try to run the commands, while no Python errors occur, the function does not seem to work. Not sure what's happening. Microelly will need to take a look at it and review my code changes at this point.
microelly2 wrote: Fri Feb 22, 2019 9:12 am ping
paullee
Post by paullee »
Thanks all for the effort :)
I have been long not able to use GeoData WB since it stop working in an AppImage version :(
