For now its enough for me maybe I can add swep edges future but if you want surface smooting, I dont have any plan for it.
FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: Geomatic Workbench
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
That's some gorgeous-looking code. I hope you keep working on that workbench. I've been thinking for a while that we really need a surveying-focused workbench, which is a bit out of my domain. I could probably figure it out, but I'd much rather let an expert do it.HakanSeven12 wrote: ↑Thu Feb 28, 2019 12:49 pm look here:
https://github.com/HakanSeven12/FreeCAD ... Surface.py
Good work!
- HakanSeven12
Thanks
- microelly2
there are some ways we can continueHakanSeven12 wrote: ↑Thu Feb 28, 2019 12:54 pmFor now its enough for me maybe I can add swep edges future but if you want surface smooting, I dont have any plan for it.
I started with alpha shapes here https://youtu.be/vpAKOTqrbPI
and some experiments on approximation
https://youtu.be/PPJ55ghd4KE
https://youtu.be/tGl4DKnoyEE
- HakanSeven12
I'm fallowing your works but I don't interest with surface smooting. I want to give ability of earthworks volume calculation to freecad.
- Joel_graff
Volumetric calculations are supported, but you need solid shapes to do it. Essentially, it's a call to a solid's Shape.Volume attribute.HakanSeven12 wrote: ↑Thu Feb 28, 2019 6:08 pm I want to give ability of earthworks volume calculation to freecad.
- microelly2
No problem, someday someone will have time to implement the smoothing.HakanSeven12 wrote: ↑Thu Feb 28, 2019 6:08 pm I'm fallowing your works but I don't interest with surface smooting. I want to give ability of earthworks volume calculation to freecad.
- HakanSeven12
I'm talking about sample lines, surfaces sections, section views and calculation between two or more surfaces. İs it support that or something like this? İf it can, that's help me a lotJoel_graff wrote: ↑Thu Feb 28, 2019 8:18 pm Volumetric calculations are supported, but you need solid shapes to do it. Essentially, it's a call to a solid's Shape.Volume attribute.
- HakanSeven12
Of course İf someone want to do something, I want to see it.microelly2 wrote: ↑Thu Feb 28, 2019 8:21 pm No problem, someday someone will have time to implement the smoothing.
- Joel_graff
Not that I'm aware of. Volumetric calculations are pretty much limited to solid shapes, I think. It's not something I've had time to explore - was waiting until I got more into building the 3D models...HakanSeven12 wrote: ↑Thu Feb 28, 2019 9:58 pm I'm talking about sample lines, surfaces sections, section views and calculation between two or more surfaces. İs it support that or something like this?
Do you have a good example of techniques that are commonly used? Something that illustrates the process step-by-step? I only ask because it's a good idea to document the problem and what the solution should look like before trying to sort it out in FreeCAD.
