FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: Trails Workbench (Transportation and Earthwork Workbench)
- new icon.png (14.91 KiB) Viewed 2101 times
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- Joel_graff
Awesome!
Icons are looking sleek
Source https://twitter.com/briantimoney/status ... 9172845568
An aside: maybe at some point this info could be plugged in to Transportation WB
- HakanSeven12
I think its not goal of trails workbench
yea, i was joking...but it could be feasible
Re: Geomatics Workbench
Hi Hakan,
Ihave made a new Scann it is on the same Place.
https://drive.google.com/drive/folders/ ... sp=sharing
HakanSeven12 wrote: ↑Sat Mar 28, 2020 11:44 amThanksREl wrote: ↑Sat Mar 28, 2020 11:00 am Hi there,
here are the links to the point clouds there are currently 2 file types.
I will expand it to 4.
https://drive.google.com/open?id=147Zjm ... Ie9n4-kXH8
I am from plant engineering. The trend in plant construction is very clear. Existing systems are scanned in order to better plan extensions and conversions.
If you don't know anything, you don't have to do anything.
- HakanSeven12
My workflow doesn't include laser scanning but it's good to see someone use trails for his own workflow.
- Joel_graff
It is pretty exciting.
- HakanSeven12
I started to work on SoGeo supported FPO objects. Finally I solved rendering issue at double variables. Its not available for you. I just writed objects. I need to add functions to it. Until then it's not useful. You can use Trails like you did before. I will activate it when it's ready.
