Did you ever get LandXML figured out for surfaces?
FreeCAD Trails Workbench (Transportation and Geomatics)
- Joel_graff
Re: Geomatics Workbench
- Joel_graff
- HakanSeven12
No I thought you'd do it.
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- HakanSeven12
No it works. I remove and reinstall it.HelmutHogreve wrote: ↑Fri May 10, 2019 9:14 am Hi,
The workbanch will not be displayed after manual installation. Is there a bug in the InitGui.py?
class GeomaticsWorkbench ( Gui.Workbench ):
- Joel_graff
It's going to be quite a while before I have time to do that, I'm afraid.
If you're interested in getting something going sooner, I can help you set up the data structures, based on what I did for alignments. It's not hard to parse the XML, but you'll have to decide how the internal dataset that your workbench uses will be structured - whether it will follow the XML schema or if it'll be unique. I opted for a unique structure because the internal alignment data doesn't map 1:1 to the XML data.
- Joel_graff
You might want to post the error message you're getting along with your system information.HelmutHogreve wrote: ↑Fri May 10, 2019 9:14 am Hi,
System information is available under Help -> About FreeCAD - click the 'Copy to clipboard' button, then paste the clipboard text into your post.
I don't know how Hakan has structured his workbench, but if you're running Python 2.7, there's a good chance that's the problem.
- HakanSeven12
My workbench works with python 3.6Joel_graff wrote: ↑Fri May 10, 2019 1:12 pm I don't know how Hakan has structured his workbench, but if you're running Python 2.7, there's a good chance that's the problem.
- HakanSeven12
Your workbench already have an Import XML function and you can add surface parse in it.Because landxml files can includes alignments and surfaces together. So its not sensible use two workbench for XML import.Joel_graff wrote: ↑Fri May 10, 2019 1:09 pm It's going to be quite a while before I have time to do that, I'm afraid.
If you can return a list of triangles vertexes we can create a mesh with that vertexes.
- Joel_graff
It's really a bit more complex than that.HakanSeven12 wrote: ↑Fri May 10, 2019 1:50 pm Your workbench already have an Import XML function and you can add surface parse in it.Because landxml files can includes alignments and surfaces together. So its not sensible use two workbench for XML import.
The XML parser I created can be re-used, but once you import that XML data, you need to parse it for your purposes. As you suggest, you need a list of triangles, so that's up to you to convert the XML data you need to do that.
So there's several parts to making the XML import / export modules work:
1. Create a 'surface importer' which uses the LandXML module to import LandXML data and parse it. This converts the XML data to a format that's useful to you in your workbench.
2. Create a 'surface exporter' which takes your internal data and builds the corresponding XML for use in other applications.
3. Ensure that the importer / exporter follow the LandXML schema (v1.2) for surfaces. This means you'll likely have to handle XML elements and tags you don't use, at least for exporting, to ensure your LandXML conforms the the schema and is readable by other applications.
Personally, I think you'll be better off if you get familiar with the XML schema for surfaces / survey data, if you aren't already. It will help make your workbench better because it will help you think about features / functions you might not yet have considered. It also helps ensure that what you do internally can be easily exported for use in other software. Really, if you can't export your data to LandXML and ensure it's 100% compatible with the schema so it can be used in other applications, you are only making your job more difficult later on.
All of my XML-related code is contained here:
https://github.com/joelgraff/freecad.tr ... roject/xml
The LandXML schema documentation is here:
http://www.landxml.org/schema/LandXML-1 ... .2Doc.html
I will certainly help you with the process, but I suspect it's a bigger job than you might think
- HakanSeven12
After I finish this workbench, I can do something for thatJoel_graff wrote: ↑Fri May 10, 2019 2:15 pm It's really a bit more complex than that.
I have a question for you how can I get tangent vector at a station?
