good evening hakan.
git clone worked... all the packages have been downloaded and the folder has been created.
though, inside freecad menu, the trails workbench doesn't appear.
I must have damaged something. In the addon manager pivy trackers appears to be installed, freecad trails appears to be installed.
I'm a bit clueless right now!
23:27:16 During initialization the error "No module named 'freecad.trails.project.support'" occurred in freecad.trails
23:27:16 --------------------------------------------------------------------------------
23:27:16 Traceback (most recent call last):
File "<string>", line 156, in InitApplications
File "C:\SOFTWARE\FreeCAD_0.19_CONDA\FreeCAD_0.19.23141-Win-Conda_vc14.x-x86_64\bin\lib\importlib\__init__.py", line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
File "<frozen importlib._bootstrap>", line 991, in _find_and_load
File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
File "<frozen importlib._bootstrap_external>", line 783, in exec_module
File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
File "C:\Users\Francesco\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\init_gui.py", line 29, in <module>
from .corridor.template import ViewTemplateLibrary
File "C:\Users\Francesco\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\corridor\template\ViewTemplateLibrary.py", line 31, in <module>
from . import TemplateLibrary, SketchTemplate
File "C:\Users\Francesco\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\corridor\template\TemplateLibrary.py", line 47, in <module>
from ...project.support import document_properties
ModuleNotFoundError: No module named 'freecad.trails.project.support'
Thanks, it finally works... I had too many freecad folders sleeping around!
I erased every appdata folder recalling freecad, I erased and fixed all the links in the advanced system panel, and with git clone recurrent procedure I have finally trails back at work!
Thanks for your support!
eccioloste wrote: ↑Tue Dec 01, 2020 10:42 am
Now there's a movie I haven't seen in a long time!
Hi @HakanSeven12,
is there a reason why the commands "Add triangle", "Delete traingle", "Swap Edge" and "Smooth Surface" are grayed out and inactive?
Thank you in advance for your help!
balrobs
Hi. We started to implementation of SoGeo nodes some times ago. So all old functions are must be rewritten. They will stay inactive until I find solutions for them. Firstly I want to finish my workflow from import points to volume tables. Then I will start to work on edit surface functions. But there is some bugs in alignment importer so I can't continue to work on other tools.
