FreeCAD Trails Workbench (Transportation and Geomatics)
HakanSeven12
Re: FreeCAD Trails Workbench (Transportation and Geomatics)
Post by HakanSeven12 »
I will 8-) I added boundary to surface object. Is you want to use it seperately use this code after you send your object to python console.
import Part
Part.show(obj.BoundaryShapes)
https://www.patreon.com/posts/54820275
Meetlat
Post by Meetlat »
Perhaps it's nice to offer some different color schemes? While googling around I found this page of an app that illustrates height of microbe scans (talking about a different scale :lol: ) It has a menu where you can select the gradient you want to show for the visualization. http://gwyddion.net/documentation/user- ... r-map.html Could be nice for your workbench? You can find the color schemes at his github here: https://github.com/cbuehler/gwyddion/tr ... /gradients
The icons the program use are also nice, perhaps some inspiration for @bitacovir (http://gwyddion.net/documentation/user- ... r-map.html)
HakanSeven12
They look good to me :) I started to work on slope analysis. Maybe I can take a look at it when I finish slope analysis.
perga
Post by perga »
Hi!
Thank you for the possibility to try out the Trails wb. Its really impressive.
I would like to import a .las pointcloud.
I get this message:
21:01:49 Running the Python command 'Import LIDAR' failed:
File "C:\Program Files (x86)\FreeCAD_weekly-builds-25311-Win-Conda_vc14.x-x86_64\Mod\freecad.trails\freecad\trails\geomatics\geoimport_gui.py", line 129, in Activated
from .geoimport import import_lidar
File "C:\Program Files (x86)\FreeCAD_weekly-builds-25311-Win-Conda_vc14.x-x86_64\Mod\freecad.trails\freecad\trails\geomatics\geoimport\import_lidar.py", line 14, in <module>
from laspy.file import File
No module named 'laspy'
What is it that Im doing wrong ?
Greetings from Norway!
perga
Post by Kunda1 »
Please always post you full About info and make sure you're using the latest version of Trails WB.
HakanSeven12
perga wrote: Fri Jul 30, 2021 7:13 pm Hi!
I get this message:
perga
You are welcome ;) don't use geodata tools import menu. Use import point file instead.
HakanSeven12
Trails reduce all coordinates to origin to fix wavy object issue. But we cant see the real world coordinate of objects at the FreeCAD standart coordinate widget. I added a coordinate widget to statusbar so you can see the utm cordinates at this widget.
https://www.patreon.com/posts/54602811
coordinate widget.PNG (2.12 KiB) Viewed 2057 times
Post by Kunda1 »
Nice!!!
Where is the code for this located specifically?
Post by Kunda1 »
HakanSeven12 wrote: Fri Aug 06, 2021 10:06 am Here
How do you assign the widget to the status bar, is it these lines?
    def __init__(self):
        Constructor
        mw = FreeCADGui.getMainWindow()
        super(CoordinateWidget, self).__init__(mw)
        mw.statusBar().addPermanentWidget(self)
