FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: Trails Workbench (Transportation and Earthwork Workbench)
I never used arch before. So I dont know. Can you explain your idea?
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
I inquired on the Arch forum we'll see what they say. https://forum.freecadweb.org/viewtopic.php?f=23&t=59476
- HakanSeven12
- Building Pad.PNG (165.29 KiB) Viewed 2555 times
Nice !
Are you really planning to build a base station on Mars ?
- HakanSeven12
You revealed my secret plan
- eccioloste
This could be useful in lots of applications!!!
Very nice!
Very nice!
- HakanSeven12
Thanks
I am trying to install FreeCAD-Trails WB ==> NO LUCK I tried (many times) the addon manager. NO LUCK .
I remove/delete the folder from C:\Users\me\AppData\Roaming\FreeCAD\Mod (for a new fresh installation). NO LUCK
I installed Trails manually. by downloading Trails, pivy_trackers and freecad_python_support. Unzipped each as follow:
Trails ==> C:\Users\me\AppData\Roaming\FreeCAD\Mod
pivy_trackers ==> C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers
freecad_python_support ==> C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers\support
NO LUCK
I read many threads including the one with a similar error to find solution. NO LUCK
Trails WB is installed but does not load and I get the attached error message:
18:29:12 During initialization the error "No module named 'pivy_trackers.support.core'" occurred in freecad.trails18:29:12 --------------------------------------------------------------------------------18:29:12 Traceback (most recent call last): File "<string>", line 156, in InitApplications File "C:\Program Files\FreeCAD 0.19\bin\lib\importlib\__init__.py", line 127, in import_module return _bootstrap._gcd_import(name[level:], package, level) File "<frozen importlib._bootstrap>", line 1014, in _gcd_import File "<frozen importlib._bootstrap>", line 991, in _find_and_load File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked File "<frozen importlib._bootstrap>", line 671, in _load_unlocked File "<frozen importlib._bootstrap_external>", line 783, in exec_module File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\init_gui.py", line 30, in <module> from .design.corridor.template import ViewTemplateLibrary File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\design\__init__.py", line 3, in <module> ContextTracker = import_class( File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\__init__.py", line 91, in import_class return getattr(import_module(path, name), name) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\__init__.py", line 84, in import_module return __import__(path, globals(), locals(), _name_list) File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers\tracker\context_tracker.py", line 27, in <module> from ..trait.base import Base File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers\trait\base.py", line 26, in <module> from ..coin.coin_enums import NodeTypes as Nodes File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers\coin\coin_enums.py", line 31, in <module> from ..support.core.const import Const File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs)ModuleNotFoundError: No module named 'pivy_trackers.support.core'18:29:12 --------------------------------------------------------------------------------
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
PLEASE HELP on how to get a working installation of FreeCAD-Trails WB.
NO LUCK
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
- HakanSeven12
Copy everything inside the support to this directory:
C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers\support\core
Many thanks Hakan for the prompt response.
After implementing your advice I can see that the Trails WB is initiated/Loaded.
However I have a new error message.
The Error Message:
22:05:27 geo1 0.050507800000000122:05:27 geo2 0.307900899999999922:05:27 non-default argument follows default argument (gl_cluster.py, line 34)22:05:27 Traceback (most recent call last): File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\init_gui.py", line 247, in Initialize from .geomatics.section import CreateGuideLines File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\geomatics\section\__init__.py", line 1, in <module> from . import CreateGuideLines File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\geomatics\section\CreateGuideLines.py", line 28, in <module> from . import gl_clusters, gl_cluster File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs)
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
PLease comment. Thanks
The Error Message:
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
