FreeCAD Trails Workbench (Transportation and Geomatics)
HakanSeven12
Re: Trails Workbench (Transportation and Earthwork Workbench)
Post by HakanSeven12 »
Are you sure you are using latest version of trails? Because this file names old. So Im thinking you are using old version of trails.
Palmtree
Post by Palmtree »
Yes Latest
I deleted Trails and down loaded a fresh copy from git hub of Trails, Pivy  and Support :
Unzip them as follow:
Trails ==> C:\Users\me\AppData\Roaming\FreeCAD\Mod
pivy_trackers   ==> C:\Users\me\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers
freecad_python_support ==> C:\Users\me\AppData\Roaming\FreeCAD\Mod\trails\pivy_trackers\support\core
NO LUCK ==> ERROR
09:40:40 geo1 0.0498279000000003709:40:40 geo2 0.307609100000000509:40:40 non-default argument follows default argument (gl_cluster.py, line 34)09:40:40 Traceback (most recent call last): File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\init_gui.py", line 247, in Initialize from .geomatics.section import CreateGuideLines File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\geomatics\section\__init__.py", line 1, in <module> from . import CreateGuideLines File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs) File "C:\Users\Fred\AppData\Roaming\FreeCAD\Mod\trails\freecad\trails\geomatics\section\CreateGuideLines.py", line 28, in <module> from . import gl_clusters, gl_cluster File "C:\Program Files\FreeCAD 0.19\bin\Lib\site-packages\shiboken2\files.dir\shibokensupport\__feature__.py", line 142, in _import return original_import(name, *args, **kwargs)
OS: Windows 10 Version 2009
Version: 0.19.24291 (Git)
Branch: releases/FreeCAD-0-19
Python version: 3.8.6+
Qt version: 5.15.2
Coin version: 4.0.1
OCC version: 7.5.0
Thanks for your quick response and patience.
Post by Kunda1 »
Please put code or log output in to bbcode code blocks, Thanks
HakanSeven12
Palmtree wrote: Thu Jul 01, 2021 11:48 pm NO LUCK ==> ERROR
I made a release for you. Download it and extract directly to your mod directory. Dont need to do anything.
https://github.com/joelgraff/freecad.tr ... 02.07.2021
Palmtree
Post by Palmtree »
Hakan, Your support and quick response is very much appreciated.
Many thanks
Palmtree
Post by Palmtree »
Kunda1 wrote: Fri Jul 02, 2021 6:42 am Please put code or log output in to bbcode code blocks, Thanks
Sorry Kunda1, What do you mean? do you mean the crash.log file (in C:\Users\me\AppData\Roaming\FreeCAD)?
Regards
Palmtree
Post by Palmtree »
Regards
HakanSeven12
You are welcome ;)
Post by Kunda1 »
This is text that is enclosed in bbcode code tags
(if you quote this reply you will see what I mean)
Palmtree
Post by Palmtree »
Noted. Thanks
. :D
