FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: Trails Workbench (Transportation and Earthwork Workbench)
Update for pads. I finished coding. Now I will start to create a new object for it. Still you need to do some minor edits. Im hapy with result for now.
https://www.patreon.com/posts/53251489
- Top.PNG (70.21 KiB) Viewed 3161 times
- Model.PNG (92.67 KiB) Viewed 3161 times
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- HakanSeven12
Re: FreeCAD Trails Workbench (Transportation and Geomatics)
First post updated.
- HakanSeven12
I added new property to point groups. You can convert your Trails wb point groups to Points wb points by using this code.
import Points
Points.show(obj.Points)
- HakanSeven12
Working on major and minor contours. Different elevation intervals, colors and line width for booth of them. Also Transparency and Placement added for surface objects.
https://www.patreon.com/posts/53710419
- major-minor.PNG (301.87 KiB) Viewed 2824 times
- HakanSeven12
Still most of the distros outdated. Is there anything to do to speed up the process?
looo wrote: ↑Fri Mar 19, 2021 4:12 pmHakanSeven12 wrote: ↑Mon Mar 15, 2021 11:09 am Yes. We are using new features in next pivy release. Until it released you cant use this wb on linux. Sorry.
I finally created a 0.6.6 release:
https://github.com/coin3d/pivy/releases/tag/0.6.6
maintainers feel free to update the pivy packages
sgrogan wrote: pinged by pinger macro
kkremitzki wrote: pinged by pinger macro
hobbes1069 wrote: pinged by pinger macro
vejmarie wrote: pinged by pinger macro
- HakanSeven12
All new surface properties added. Is there any property you want to see?
https://www.patreon.com/posts/54124621
- surface properties.png (12.64 KiB) Viewed 2488 times
- HakanSeven12
- side.PNG (118.99 KiB) Viewed 2364 times
- top.PNG (40.73 KiB) Viewed 2364 times
- HakanSeven12
Thanks
+1 hakan! Keep going!!!
