FreeCAD Trails Workbench (Transportation and Geomatics)
- HakanSeven12
Re: FreeCAD Trails Workbench (Transportation and Geomatics)
- pad.PNG (155.28 KiB) Viewed 4363 times
Support me: Hakan Seven on Patreon
Modern UI: Modern UI on FreeCAD Forum
Trails Workbench: Trails Workbench on FreeCAD Forum
- HakanSeven12
Finally I figured out howto import surfaces in landxml files There is some bugs but it works. That is the first test. I exported surfaces to landxml in Civil 3D than imported to FreeCAD.
https://www.patreon.com/posts/56458450
- Capture.PNG (241.13 KiB) Viewed 4208 times
- HakanSeven12
Update: with last commits cogo points support added for LandXML importer.
https://www.patreon.com/posts/56583872
- Joel_graff
This looks great!
- HakanSeven12
Thanks
- HakanSeven12
I have a good news and a bad news about pads.
Create pad function useable now. Select a closed wire than select a Trails surface and click create pad button.
Bad news is you need to use FreeCAD 0.20(25844) or higher
About pads its mostly static for now but I want to create a seperate object for it. So you can define cut and fill slopes.
https://www.patreon.com/posts/56744363
- pad.PNG (46.7 KiB) Viewed 3817 times
This is really shaping up, well done
- HakanSeven12
Thanks
Can't wait to try this out! Thanks!
- HakanSeven12
You are welcome
