Trails Workbench (Transportation and Earthwork Workbench)
Joel_graff
Re: Geomatics Workbench
Postby Joel_graff » Sun Aug 04, 2019 2:11 am
HakanSeven12 wrote:
Fri Aug 02, 2019 12:00 pm
I think FreeCAD need a fix that works for all workbenchs.
I agree, but this is a problem at the scenegraph level - Coin3D uses single-precision floating point and since the next option (OpenSceneGraph) is the same, there's no way to really fix it.
The solution, if it can be accomplished, lies in data segmentation, I think. And I think how the data gets divided up really depends on the type of modeling that's being done. I could be wrong about that, though.
In any case, before a general solution can be proposed for FreeCAD, it needs to be prototyped. And really, I think this problem is really limited to the sort of datasets that you and I work with - geospatial stuff. So if a solution is to be implemented, it should be done here.
In any case, I'm willing to at least kick it around a bit and see if I can make something work - but I need your dataset to do that - and maybe an example post, showing exactly where the errors appear.
paullee
Postby paullee » Sun Aug 04, 2019 2:40 am
The WB looks promising and thanks there had been lots of works. Hope something can be done ? :(
Giovanni Bianchessi
Postby Giovanni Bianchessi » Tue Aug 20, 2019 9:37 am
On my Mac (macOS 10.13) and FreeCAD_0.19-17681-OSX-x86_64-conda-Qt5-Py3 this WB does not work "out of the box"
When Freecad starts (from terminal) a couple of errors are shown:
- name __file__ undefined from init.py
- ICONPATH ... (sorry, but at this moment I can't remember the error)
... and the Geomatics workbench is not loaded.
In order to avoid those errors and made the workbench to run I have made some modifications borrowing the techinique from another, working, workbench:
- renamed file init.py to Geomatics_locator.py
- deleted the few lines of code and left only the commented header
- Modified the file InitGui.py as follows:
class GeomaticsWorkbench ( Gui.Workbench ):
import os
import Geomatics_locator
GeomaticsPath = os.path.dirname( Geomatics_locator.__file__ )
ICONPATH = os.path.join(GeomaticsPath, 'Resources/icons')
#print (ICONPATH)
I don't know if it is the right way, but now the Geomatics Workbench is loaded in FreeCAD.
I activated it and its toolbar has shown up, and I suppose, since I have no data to test it, it is usable too.
Regards
Giovanni
Joel_graff
Postby Joel_graff » Wed Aug 21, 2019 12:40 pm
Unfortunately, it seems as though @HakanSeven isn't supporting the Geomatics WB anymore. Your fix shouldn't be lost, however.
I recommend submitting a pull request to his github repo and see if he merges it.
If not, I will fork it so we can merge the code there, unless you'd like to be the Geomatics maintainer, of course. :)
HakanSeven12 wrote: ping
Giovanni Bianchessi
Postby Giovanni Bianchessi » Wed Aug 21, 2019 12:57 pm
I have no idea of what Geomatics WB should do.
Only for the sake of curiosity I have modified the code to make it run.
But I am not able to be a maintainer.
So if you want, go on.
Joel_graff
Postby Joel_graff » Wed Aug 21, 2019 1:16 pm
ok. I'll try to integrate your changes.
Thanks
bidandou
Postby bidandou » Sat Sep 07, 2019 9:58 pm
HakanSeven12 allows added me as a collaborator to the Geomatics Workbench Repository.
A want to continue working on the WB. My vision is to have functionalities similar to : I will also try to fix any bug.
For more information, I create a TODO file in the main repository.
HakanSeven12
Postby HakanSeven12 » Sun Sep 08, 2019 9:38 am
:clap:
vocx
Postby vocx » Wed Sep 18, 2019 6:29 pm
ping
ping
Hi, I'm editing the Release notes 0.19 page. I'm including your workbench. It would be nice if you could post in this thread a single image that showcases your workbench. It doesn't have to be very complex, but something that attracts potential new users. In the Release notes 0.19 page, go to "Additional workbenches" to see some images used. For example, the image used in the "CurvedShapes Workbench" is quite good, as it shows what it is intended for. The image should be big enough, like 600x400 px, although it will be displayed at 400 px width. We don't want it to be too small and blurry.
I've considered using the images already posted in this thread: imported terrain, curves by sections, but maybe you'd like to showcase something in particular.
HakanSeven12
Postby HakanSeven12 » Thu Sep 19, 2019 7:39 am
curves by sections
You can use this images.
