Geomatics Workbench
Joel_graff
Re: Geomatics Workbench
Postby Joel_graff » Fri Sep 20, 2019 11:18 am
@HakanSeven - BTW, I know you aren't directly involved with the project anymore, but I'd suggest you set up a KanBan board (a project board) on github and start adding issues to it so this stuff can get tracked. You've built a really good thing. It's just going to take a little time and effort to work through the issues to make it really useful.
Tracking issues on a project board will help out the others who are also contributing to your WB. (You're also pretty lucky to have contributors ;) )
HakanSeven12
Postby HakanSeven12 » Fri Sep 20, 2019 12:17 pm
Maybe @bidandou can do it :)
bidandou
Postby bidandou » Fri Sep 20, 2019 2:10 pm
Project Board created on the Github Repo.
Github issues tracker is up to date.
For a long term vision and a list of desired features see TODO file .
Contributions are welcome.
paullee
Postby paullee » Fri Sep 20, 2019 2:21 pm
HakanSeven12 wrote:
Fri Sep 20, 2019 8:45 am
paullee wrote:
Fri Sep 20, 2019 2:59 am
Any idea?
Your data file has more than one whitespace between coordinates. The wb only allow one whitespace.
Thanks and testing.
BTW, what is the difference with your Import Point Files vs Points Workbench Import a Point Cloud?
HakanSeven12
Postby HakanSeven12 » Fri Sep 20, 2019 3:38 pm
Thanks and testing.
My importer more flexible. You can see a preview of your file and you can specify data columns. Also you can import coordinates from every text file format by using my importer (point clouds or other surveyor point file formats) and you can import more than one file at the same time.
Postby Kunda1 » Fri Sep 20, 2019 7:48 pm
Maybe the importer should be ported to Point WB?
bidandou
Postby bidandou » Fri Sep 20, 2019 7:55 pm
Why not
I think that there is a good synergy between the Geomatics WB and the Point + Mesh ones
paullee
Postby paullee » Fri Sep 20, 2019 8:49 pm
Thanks and testing.
Yes, thanks, that's apparent :)
bidandou
Postby bidandou » Sat Sep 21, 2019 7:45 pm
paullee wrote:
Thu Sep 19, 2019 6:23 pm
Trying to use GeoData and Geomatics again, but unfortunately not working
Import OSM (GeoData)
Running the Python command 'Geodat_importOSM' failed:
  File "<string>", line 476, in Activated
  File "/home/paullee/.FreeCAD/Mod/geodata/geodat/import_osm.py", line 27, in <module>
    from say import *
No module named 'say'
Running same Import OSM on Geomatics WB
I try to read data from cache file ...
/home/paullee/.FreeCAD/geodat3/50.340722-11.232647-0.25
no cache file, so I connect to  openstreetmap.org...
http://api.openstreetmap.org/api/0.6/map?bbox=11.229140688639552,50.338475818508535,11.236153311360448,50.342968181491464
  File "/home/paullee/.FreeCAD/Mod/Geomatics/GeoDataWB/import_osm.py", line 128, in import_osm2
    f = open(fn, "r")
FileNotFoundError: [Errno 2] No such file or directory: '/home/paullee/.FreeCAD/geodat3/50.340722-11.232647-0.25'
During handling of the above exception, another exception occurred:
  File "/home/paullee/.FreeCAD/Mod/Geomatics/GeoDataWB/import_osm.py", line 695, in downloadData
    rc = import_osm2(float(b), float(l), float(s)/10, self.root.ids['progb'], self.root.ids['status'], elevation)
  File "/home/paullee/.FreeCAD/Mod/Geomatics/GeoDataWB/import_osm.py", line 141, in import_osm2
    import requests
ModuleNotFoundError: No module named 'requests'
FreeCAD_0.19-17646-Linux-Conda_Py3Qt5_glibc2.12-x86_64.AppImage
on Fedora 30
Python version: 3.7.3
should install requests module
pip install requests
Also all the fixes made by HakanSeven in Geomatics WB are now available in GeoData (a pull request has been created)
Postby Kunda1 » Sat Sep 21, 2019 7:56 pm
https://github.com/microelly2/geodata/pull/17
In my experience, @microelly2 hasn't responded to many PRs that are py3 related, unfortunately. I hope this one will be different.
Relevant: https://github.com/microelly2/geodata/pull/7
