Trails Workbench (Transportation and Earthwork Workbench)
paullee
Re: Geomatics Workbench
Postby paullee » Sat Sep 21, 2019 8:08 pm
bidandou wrote:
Sat Sep 21, 2019 7:45 pm
should install requests module
pip install requests
Also all the fixes made by HakanSeven in Geomatics WB are now available in GeoData (a pull request has been created)
Thanks maintaining this WB and looking into this problem :)
Realised 'request' should be kind of python module, but seem haven't found any missing in Fedora 30... no really idea which one is needed.
Installed (being told a few of them had been installed)... same result
Screenshot from 2019-09-22 04-02-40.png (230.87 KiB) Viewed 427 times
bidandou
Postby bidandou » Sat Sep 21, 2019 8:24 pm
Should be this one I suppose
Capture d’écran de 2019-09-21 21-20-25.png (64.15 KiB) Viewed 421 times
paullee
Postby paullee » Sun Sep 22, 2019 12:13 am
Thanks ... should have installed something similar on Fedora30 ...
[paullee@localhost ~]$ sudo dnf install python2-requests.noarch python3-requests.noarch
Package python2-requests-2.21.0-2.fc30.noarch is already installed.
Package python3-requests-2.21.0-2.fc30.noarch is already installed.
Dependencies resolved.
Nothing to do.
HakanSeven12
Postby HakanSeven12 » Wed Dec 11, 2019 9:54 am
No need scipy for triangulation anymore.
paullee
Postby paullee » Tue Dec 17, 2019 7:55 pm
Thanks, somehow would attempt again to see if it works on Fedora 30.
paullee
Postby paullee » Tue Dec 17, 2019 7:59 pm
Joel_graff wrote:
Sun Aug 04, 2019 2:11 am
HakanSeven12 wrote:
Fri Aug 02, 2019 12:00 pm
I think FreeCAD need a fix that works for all workbenchs.
I agree, but this is a problem at the scenegraph level - Coin3D uses single-precision floating point and since the next option (OpenSceneGraph) is the same, there's no way to really fix it.
The solution, if it can be accomplished, lies in data segmentation, I think. And I think how the data gets divided up really depends on the type of modeling that's being done. I could be wrong about that, though.
In any case, before a general solution can be proposed for FreeCAD, it needs to be prototyped. And really, I think this problem is really limited to the sort of datasets that you and I work with - geospatial stuff. So if a solution is to be implemented, it should be done here.
In any case, I'm willing to at least kick it around a bit and see if I can make something work - but I need your dataset to do that - and maybe an example post, showing exactly where the errors appear.
Read this thread again and realize this underlying problem - anything @wmayer @yorik can do about this?
I remember I tried to place some Arch Objects at 'real world coordinate' and probably due to same underlying problem, there was weird result.
So it is fundamental if FC can be used at 'real world coordinate' ?
Joel_graff
Postby Joel_graff » Tue Dec 17, 2019 8:58 pm
The only way to manage the issue is to "normalize" coordinates to within single-precision limits (I forget exactly what those are atm). That means determining an "offset" position for those coordinates and setting a placement at that position, then locating the larger coordinates relative to that placement. Of course, if the placement is too large, then it needs to be offset relative to another placement and so on.
Whether or not this problem is worth solving internally in FC is certainly a matter of valid use cases. FC has been in existence for nearly 20 years and I have not seen this use case come up in the forum archives (which date back to 2011), so it has to be rare. Still having a robust, standardized approach to handle coordinate systems that exceed SP limits would be nice. :)
HakanSeven12
Postby HakanSeven12 » Tue Dec 17, 2019 9:04 pm
I agree
paullee
Postby paullee » Wed Dec 18, 2019 4:46 am
Thanks taking time to explain.
In architural design, we used to put the layout over survey map which is usually prepare according to ' real world coordinates'. We can thus read the coordinates of a building corner , grid for setting-out purpose, no problen in Autocad so far.
I thought for your civil . transportation design, you need thsame informatiom ?
Joel_graff
Postby Joel_graff » Wed Dec 18, 2019 12:26 pm
Yup. Hakan and I are pretty much the only use case for large-scale coordinate systems around here. Which leaves it up to us to fix it. :)
But it's good you mention your need as well. You shouldn't have to work too hard to solve your situation, as I suspect you don't have to produce large terrain maps like the Geomatics workbench would, but I still think it's a good idea to lobby for an internal FC approach to solving this issue.
I've tried to come up with a way to handle large coordinate systems seamlessly in FC (that could be incorporated into the core) and I haven't really been successful...
