Trails Workbench (Transportation and Earthwork Workbench)
HelmutHogreve
Re: Geomatics Workbench
Postby HelmutHogreve » Mon May 13, 2019 8:04 am
Joel_graff wrote:
Fri May 10, 2019 1:12 pm
HelmutHogreve wrote:
Fri May 10, 2019 9:14 am
The workbanch will not be displayed after manual installation. Is there a bug in the InitGui.py?
class GeomaticsWorkbench ( Gui.Workbench ):
You might want to post the error message you're getting along with your system information.
System information is available under Help -> About FreeCAD - click the 'Copy to clipboard' button, then paste the clipboard text into your post.
I don't know how Hakan has structured his workbench, but if you're running Python 2.7, there's a good chance that's the problem. ;)
After installing Geomatics in .. \ Mod \ Geomatics and then starting FreeCAD, nothing appears from the workbanch. Geomatics does not show up in the workspace. Thus, I have no error message. :?
I use FreeCAD 0.18. Python version is 3.6.6.
HakanSeven12
Postby HakanSeven12 » Mon May 13, 2019 10:21 am
Go to "Help->About FreeCAD" and Click "Copy to clickboard" button and paste it to your reply.
Joel_graff
Postby Joel_graff » Mon May 13, 2019 12:22 pm
Oddly, it doesn't show up for me, either.
No errors in report view.
EDIT: I take that back. I don't have scipy installed. Unfortunately, that takes some doing on this machine, so I'm not going to go after it atm.
OS: Windows 7
Version: 0.19.16474 (Git)
Hash: 746997e48411f22a150b95b6fdbb9b02cbe741d5
Python version: 3.6.6
Qt version: 5.6.2
Joel_graff
Postby Joel_graff » Mon May 13, 2019 12:26 pm
Open the report view in FreeCAD and check for errors. You may be missing scipy, which would prevent the workbench from ever loading.
HakanSeven12
Postby HakanSeven12 » Mon May 13, 2019 1:06 pm
Installation added to topic.
HelmutHogreve
Postby HelmutHogreve » Tue May 14, 2019 8:38 am
Sorry,
Although I know some CAD systems. FreeCAD is new to me though. My English is not the best either. I try my best
Here are the desired data:
OS: Windows 7
Version: 0.18.16093 (Git)
Branch: releases/FreeCAD-0-18
Hash: 690774c0effe4fd7b8d2b5e2fb2b8c8d145e21ce
Qt version: 5.6.2
Freecad.log
Log File
(4.73 KiB) Downloaded 14 times
HakanSeven12
Postby HakanSeven12 » Tue May 14, 2019 8:56 am
Sorry,
OS: Windows 7
Qt version: 5.6.2
Freecad.log
In log file
  File "<string>", line 120, in InitApplications
  File "<string>", line 3, in <module>
  File "C:\Users\helmut.hogreve\AppData\Roaming\FreeCAD\Mod\Geomatics\Surfaces\CreateSurface.py", line 3, in <module>
    import scipy.spatial
ModuleNotFoundError: No module named 'scipy'
As you can see it's give scipy error you need to install scipy first.
Find and download scipy‑1.2.1‑cp36‑cp36m‑win_amd64.whl in here: https://www.lfd.uci.edu/~gohlke/pythonlibs/
Open it and copy two folder to C:\Program Files\FreeCAD 0.18\bin\Lib\site-packages
Joel_graff
Postby Joel_graff » Tue May 14, 2019 11:50 am
Python packages may also be installed using pip. You can test it by opening a terminal window (command shell in Windows) and typing:
"pip3 install scipy"
HelmutHogreve
Postby HelmutHogreve » Tue May 14, 2019 1:54 pm
Has worked so far. Only, there is still a problem.
Freecad_2.log
Log Datei zum 2.ten
(4.04 KiB) Downloaded 11 times
HelmutHogreve
Postby HelmutHogreve » Tue May 14, 2019 1:56 pm
Thanks, works great with pip. Again learned something. :D
