Type of fixing / bracket...
Brutha
Post by Brutha »
Hi All,
This is not really a Freecad question, but since I'm doing some design with Freecad involved, I thought it was ok to post!!
I'm building a new computer for my rowing machine, and I need to fix mount a reed switch connected to a replacement front panel. The sensor will go on the end of the bracket where I've highlighted in red.
I thought I could do it with some bracket type arrangement with a bolt going through, so I can adjust the bracket position easily left and right. Does anyone know if the object highlighted in green is a thing with a name that I can actually buy, or is this something I'd have to make myself?
Thanks!
Brutha
PS - thanks to whoever made the fasteners workbench, very impressed with that!
Screenshot 2019-03-08 at 13.45.13.png (165.06 KiB) Viewed 494 times
Syres
Re: Type of fixing / bracket...
Post by Syres »
I put into Google Search 'tophat section bracket' and it returned similar designs as your highlighted item.
Brutha
Post by Brutha »
Syres wrote: Fri Mar 08, 2019 2:07 pm I put into Google Search 'tophat section bracket' and it returned similar designs as your highlighted item.
Aha - yes, top hat seems to be the word I was looking for! Also "stand off" bracket which appeared in connection with it when I searched your term.
Thanks!!!
