Ticket #3855 - UI becomes unresponsive when attempting to download and use DXF import libraries (python legacy)
FreeCAD_Bot
Postby FreeCAD_Bot » Tue Mar 12, 2019 12:00 pm
'Ticket issue #3855 - UI becomes unresponsive when attempting to download and use DXF import libraries (python legacy)'
Description
When not using legacy, it appears to draw nothing at all, but does not fail in the same way. The UI becomes unresponsive at the OS level, with Ctrl+Alt+T and similar shortcuts not working. This makes it difficult to gather more information about the problem, I ended up restarting with the power button after waiting several seconds. I also tried after installing (successfully through the add-on manager) the dxf_library add-on, with the same result.
Steps to Reproduce
  1. Start up FreeCAD
  2. Go to Edit->Preferences->Import-Export and check
    FreeCAD wrote:Use legacy python importer
    and
    FreeCAD wrote:Automatic update (legacy importer only)
  3. Apply the changes and attempt to open my DXF file
  4. Wait
  5. Wait longer
  6. Try to stop the operation
  7. Try to close FreeCAD through the UI
  8. Try to access a terminal
  9. Restart the machine with the power button
Additional Information
OS: Ubuntu 18.04.2 LTS
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.15rc1
Qt version: 5.9.5
Re: Ticket #3855 - UI becomes unresponsive when attempting to download and use DXF import libraries (python legacy)
Postby Kunda1 » Thu Jan 16, 2020 5:32 pm
bump
vocx
Postby vocx » Thu Jan 16, 2020 5:51 pm
This should be re-tested with 0.18 and 0.19.
The description is also vague. That the system becomes unresponsive could be a sign of a failed Internet connection; maybe a library that fetches the files from the web servers hangs.
I think this bug report is quite generic and it's probably better closed.
Zolko
Postby Zolko » Fri Jan 17, 2020 4:09 pm
This should be re-tested with 0.18 and 0.19. The description is also vague.
When opening (importing) a large STEP file (60Mb, not that large) the UI freezes. The entire UI of the computer: mouse still responsive, but no keyboard input. And all 4 cores at 100%.
Happens with all AppImages since a long time.
vocx
Postby vocx » Fri Jan 17, 2020 4:40 pm
When opening (importing) a large STEP file...
And how is this related to this thread? This thread is about freezing when opening a DXF file, not a Step file. They use different importers, so if they freeze, we cannot assume the same cause.
Open a new thread, and if necessary, a new ticket for your problem.
