Automate Reinforcement GSoC proposal
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Post by Suraj Dadral »
Hello everyone,
I have create function makeTwoTiesSixRebars() to create TwoTiesSixRebars column reinforcement.
commit
Example:
from ColumnReinforcement import TwoTiesSixRebars
TwoTiesSixRebars.makeTwoTiesSixRebars(40, 30, 50, 45, 20, True, 5, (10, 10), (135, 135), (2, 2), 20, -40, -40, "StraightRebar", "Top Inside", "x-axis", 2, 30)
But there is one problem with LShapeRebars with hook extend along x-axis. It is as shown below:
TwoTiesSixRebars.makeTwoTiesSixRebars(40, 30, 50, 45, 20, True, 5, (10, 10), (135, 135), (2, 2), 20, -40, -40, "LShapeRebar", "Top Inside", "x-axis", 2, 30)
In above image, the central main rebars direction can be along +ve x-axis or -ve x-axis.
I am in doubt if LShapeRebars with this configuration is possible in actual reinforcement?
The above problem can be easily eliminated by removing option to choose hook_extend_along, which may be "x-axis" or "y-axis", and setting it default to "y-axis".
Please give your suggestions.
Thanks,
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Mon Jul 08, 2019 5:34 pm But there is one problem with LShapeRebars with hook extend along x-axis. It is as shown below:
Hi Suraj,
As I saw, that you have created LShape rebar with "Top Inside" configuration which is fine. It's not important that middle LShape rebars point to +x or -x axis, important is they are inside the stirrup.
Also, please share your next plans. I suggest after completion of two tie reinforcement you should go for a circular column and then beam reinforcement.
Thanks,
Amritpal Singh
Github, Like my work, sponsor me!
Suraj Dadral
amrit3701 wrote: Wed Jul 10, 2019 8:48 am
Thanks @amrit3701
My next plan is to complete TwoTiesSixRebars column reinforcement and circular column reinforcement before 18 July, 2019.
And after that I will create user documentation and start implementation of beam reinforcement.
Thanks,
Suraj Dadral
Hello everyone,
There is one more problem:
When I create TwoTiesSixRebars column reinforcement with different values for diameter of tie1 and tie2, then it will produce column reinforcement as below image:
TwoTiesSixRebars.makeTwoTiesSixRebars(40, 30, 50, 45, 20, True, 5, (8, 20), (135, 135), (2, 2), 20, -40, -40, "StraightRebar", "Top Inside", "x-axis", 2, 30)
In above image, rebars crosses the tie.
This can be fixed by setting size of both ties equal.
I also discussed this with my civil engineer friends and according to them, diameter of all ties in column is equal in 99% cases.
Please give your suggestions about this.
Thanks,
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Thu Jul 11, 2019 9:21 am In above image, rebars crosses the tie.
Place inner ties to stirrup which has a bigger diameter. :)
Amritpal Singh
Suraj Dadral
amrit3701 wrote: Thu Jul 11, 2019 9:47 am
To do as suggested above, we will not be able to use function makeSingleTieFourRebars.
So, I will re-implement function makeTwoTiesSixRebars to do this work.
Thanks,
hardeeprai
Post by hardeeprai »
Suraj Dadral wrote: Mon Jul 08, 2019 5:34 pmI have create function makeTwoTiesSixRebars() to create TwoTiesSixRebars column reinforcement.
<snip>
<snip>
You may do following:
1. Corners bars bent at 45 degrees to side.
2. Non-corner bars bent perpendicular to side
Above mean, all bars bent towards centre (almost) of section.
H.S.Rai
hardeeprai
Suraj Dadral wrote: Thu Jul 11, 2019 9:21 amI also discussed this with my civil engineer friends and according to them, diameter of all ties in column is equal in 99% cases.
Take it 100%
H.S.Rai
hardeeprai
TwoTiesSixRebars.makeTwoTiesSixRebars(<snip>)
TwoTiesSixRebars.makeTwoTiesSixRebars()
may be named as:
TwoTiesSixRebars.make()
I mean, rather than
foo.foo()
use
foo.make()
H.S.Rai
ebrahim raeyat
Post by ebrahim raeyat »
hardeeprai wrote: Thu Jul 11, 2019 4:24 pm
Take it 100%
110 % !! because it's for shear resistance and must be equal i think.
