Automate Reinforcement GSoC proposal
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Post by Suraj Dadral »
amrit3701 wrote: Wed Aug 07, 2019 1:58 pm
Suraj Dadral wrote: Sat Aug 03, 2019 4:56 pm
Please check and give your suggestions.
Looks good! :)
Thanks
I have completed storing reinforcement data into rebar groups as per commit: https://github.com/SurajDadral/FreeCAD- ... 3f1afca815
Now, I am working on creating ui to create beam reinforcement.
Previews:
When user will click on edit button, a new dialog box will be opened like rebar distribution dialog box, in which user will give input data.
Please check if it is user friendly or may suggest better way.
Thanks,
ebrahim raeyat
Post by ebrahim raeyat »
Thanks @Suraj Dadral.
Do you plan for additional rebar in beams? I mean rebar that not continued throughout beam.
like this one:
https://github.com/chakkreetiya/FreeCAD-Rebars
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Wed Aug 07, 2019 5:23 pm When user will click on edit button, a new dialog box will be opened like rebar distribution dialog box, in which user will give input data.
I tested your code and currently it is only working through the Python console. So, I suggest to integrated it with beam reinforcement dialog fast and write its user-documentation as the deadline of last evaluation is closer.
Amritpal Singh
Github, Like my work, sponsor me!
Suraj Dadral
ebrahim raeyat wrote: Sat Aug 10, 2019 6:07 pm Thanks @Suraj Dadral.
Thanks @ebrahim for letting me know. I will do it after GSoC.
Suraj Dadral
amrit3701 wrote: Sun Aug 11, 2019 6:02 pm
Yes @amrit3701, I am trying to complete implementation of beam reinforcement dialog box. I hope I will complete it by 14 August, after that we will left with 12 days (26 August deadline of GSoC) to write user-documentation.
Some previews of beam reinforcement dialog box:
Thanks,
Suraj Dadral
Suraj Dadral wrote: Mon Aug 12, 2019 12:04 pm
Hello everyone,
I have completed creation of beam reinforcement through ui.
Example output with default values:
Please test it and give your suggestions.
Now, I will start writing user documentation for beam reinforcement as suggested by @amrit3701.
Thanks,
beam.FCStd
(81.79 KiB) Downloaded 117 times
chakkree
Post by chakkree »
From your dialog, I have some question.
1. How do I set the top rebars with L-shaped, "2-DB20"?
2. How do I set the bottom rebars with straight-rebar, "2-DB20"?
beam02.FCStd
(61.69 KiB) Downloaded 146 times
Suraj Dadral
chakkree wrote: Thu Aug 15, 2019 4:31 am From your dialog, I have some question.
Hi @chakkree,
To set as above. You can edit Number#Diameter@Offset to have only one set as below image.
And then edit rebar type value to LShapeRebar.
After that edit hook orientation value to front inside.
For this, you can do same as above for bottom reinforcement, but select StraightRebar as rebar type.
Please let me know if anything is not clear.
Thanks,
Post by yorik »
Hi Suraj,
As you know we need to finish this week. I am looking at your code now, your work is basically in the "automate" branch on your github repo, is that correct? I think it would be good if you could write a wrap-up explaining how to use your work, how to install, etc. I know you are busy writing docs, so probably you are doing this already.
Great work so far anyway! Congrats!
amrit3701
Post by amrit3701 »
yorik wrote: Tue Aug 20, 2019 2:10 pm As you know we need to finish this week. I am looking at your code now, your work is basically in the "automate" branch on your github repo, is that correct? I think it would be good if you could write a wrap-up explaining how to use your work, how to install, etc. I know you are busy writing docs, so probably you are doing this already.
Hi Yorik and Suraj,
The stable code of Suraj work is present in `gsoc19` branch (https://github.com/amrit3701/FreeCAD-Re ... ree/gsoc19). Right now, code related to beam reinforcement is not merged yet. Anyway, I am planning when beam reinforcement will complete then I merge `gsoc19` branch into `master` branch. Then everyone can install Suraj code from the addon manager.
@Suraj,
I am trying to create reinforcement in beam by using your beam reinforcement dialog (`suraj/gsoc19-two-legged-stirrup` branch). It only creates stirrups rebars, no longitudinal rebars. Also, it throws below error in the `Report view`:
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/MainBeamReinforcement.py", line 1171, in clicked
    self.accept(button)
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/MainBeamReinforcement.py", line 1233, in accept
    self.FaceName,
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/TwoLeggedBeam.py", line 240, in makeReinforcement
    structure,
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/BeamReinforcement/TwoLeggedBeam.py", line 306, in makeTopReinforcement
    facename, structure
  File "/Users/ambu/Library/Preferences/FreeCAD/Mod/Reinforcement/Rebarfunc.py", line 701, in getFacenamesforBeamReinforcement
    return (facename_for_tb_rebars, facename_for_s_rebars)
UnboundLocalError: local variable 'facename_for_s_rebars' referenced before assignment
Also, there is no image of beam reinforcement present in the dialog box. Please take a look on this issue.
Amritpal Singh
