Automate Reinforcement GSoC proposal
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Post by Suraj Dadral »
hardeeprai wrote: Mon May 13, 2019 1:11 pm
Suraj Dadral wrote: Sat May 11, 2019 3:18 pmSo, we will take input for diameter and amount of rebars as:
Amount@Diameter: amount@diameter + amount@diameter + amount@diameter
"@" is normally used for spacing, “ϕ” or "#" is used for diameter. So better in above replace @ with #.
In your post https://forum.freecadweb.org/viewtopic. ... 90#p307712 and in image https://forum.freecadweb.org/download/file.php?id=83472 use Number in place of Amount in 7th option under ties ( i.e. Radio button Amount | Spacing ).
OK, I will do that.
I will try to complete implementation of GUI, so that we can create reinforcement for column with configuration "SingleTieFourRebars" using function "makeSingleTieFourRebars".
Thanks,
bernd
Post by bernd »
hardeeprai wrote: Mon May 13, 2019 1:13 pm
bernd wrote: Mon May 13, 2019 11:11 amjust would like to throw in we gone use two or three stirrups quite often ... See attached pic
@bernd
Which tool you are using to produce such drawings?
Nemetschek Allplan. I our office we do hundreds of reinforce model (and drawing) each year with Allplan.
bernd
Post by bernd »
Allplan has such tools the GSoC project is about too. Means pre adjusted objecst where the user puts in some values and the whole object is reinforced. For 99 % of reinforcement drawings we do not use these tools. Mostly we gone use two general tools which works as follows:
- tool one: define the shape of a reinforcement rebar (each rebar shape gets a ID) (we gone use the BIM concrete model to create the rebar shape, but the rebars are not parametric connected to the concrete. Other software is more parametric, for example Tekla. There the rebars are parametric connected to the concrete.)
- tool two: take some rebar shape and define the vector and the rebar space (or the rebar count) of the rebar distribution along the vector
Quite often step two is repeated with the same rebar shape. Or may be later the day one comes back and makes another rebar distribution with a rebar shape defined earlier the day. Thus it is possible one rebar shape object has dozens of different rebar distribution objects in one floor. As an example, if there are 20 columns of the same size, there will only be one rebar shape object for the stirrups and one rebar shape object for the straight rebars, but a lot more distribution objects for all the columns. In FreeCAD one would may be use a clone for such problem, but this does not really exist in Allplan reinforcement so we gone use rebar distribution object copies.
But this is just what we gone do in the office here. Others might be better with the kind of tools like they are developt in the GSoC project.
yorik
Founder
Post by yorik »
What would be cool to think of, is a preset system. Like, you configure all rebars how you like for one column. Then you would be able to store all the setup, and reapply it on another column.
But no need to break your head on this just yet @Suraj :D just a possible idea for the future.
Well done so far! This is beginning very well!
ebrahim raeyat
Post by ebrahim raeyat »
I finished almost beam requirements for drawing longitudinal beam's profile. next step i want to import architectural IFC model from another software (ETABS in my case) to freecad. i want to read dimensions of beam from model, then match rebar information for each beam and then create BeamType elements. i appreciate if you have an idea for this purpose. very thanks.
github: https://github.com/ebrahimraeyat/pyconcrete
Suraj Dadral
Suraj Dadral wrote: Mon May 13, 2019 1:17 pm
Hello @all
Now, we can create SingleTieFourRebars Column Reinforcement through GUI :) . And here is related git commit: commit
How to use?
- Clone branch "gsoc19-ui" from repository https://github.com/SurajDadral/FreeCAD-Reinforcement and move repository to appropriate place.
- Open new file and select face of column.
- In FreeCAD's python console, paste following code snippet:
from ColumnReinforcement import ColumnReinforcement
FreeCADGui.Control.showDialog(ColumnReinforcement._ColumnTaskPanel())
Limitations:
- It doesn't store values like HookOrientation, HookExtendAlong etc.
- Once Apply button is clicked, user can't modify created rebars through same dialog box.
Possible Solution:
- Create Object in Tree View of FreeCAD, where user will double click on object to edit created Reinforcement.
Please review and suggest changes.
Is the above solution is appropriate or is there any other way to do?
Thanks,
Suraj Dadral
yorik wrote: Mon May 13, 2019 9:55 pm What would be cool to think of, is a preset system. Like, you configure all rebars how you like for one column. Then you would be able to store all the setup, and reapply it on another column.
The idea is very interesting to implement. I will definitely do it in future and having master configuration file (or number of configuration files) for Rebar Addon will play important role in this.
yorik wrote: Mon May 13, 2019 9:55 pm Well done so far! This is beginning very well!
Thanks @yorik :D
Suraj Dadral
Today, I added initialization button to drop down menu of Rebar Addon.
Now, user create SigleTieFourRebars Column Reinforcement through UI by clicking on item "Column Reinforcement" in drop down menu of Rebar Addon.
And related git commit is here: https://github.com/SurajDadral/FreeCAD- ... 3572a6b8bc
Thanks,
amrit3701
Post by amrit3701 »
Suraj Dadral wrote: Thu May 16, 2019 9:19 pm Limitations:
Possible Solution:
I think we can add Group Python feature object which holds all the rebars use for creating reinforcement and store properties like HookOrientation, HookExtendAlong etc. for modifying created rebars. The structure element hold this group instead of rebars. Something like below image.
yorik wrote:
Any comments?
Done. See PR.
Amritpal Singh
Github, Like my work, sponsor me!
Suraj Dadral
While creating stirrups, if we set offset of tie to zero, then the bottom stirrup will go out of column as in below image:
To fix above, I modified file ArchRebar.py of Arch workbench and here is modified file content:
import FreeCAD,Draft,ArchComponent,DraftVecUtils,ArchCommands
from FreeCAD import Vector
if FreeCAD.GuiUp:
    import FreeCADGui
    from DraftTools import translate
    from PySide.QtCore import QT_TRANSLATE_NOOP
else:
    # \cond
    def translate(ctxt,txt):
        return txt
    def QT_TRANSLATE_NOOP(ctxt,txt):
        return txt
    # \endcond
## @package ArchRebar
#  \ingroup ARCH
#  \brief The Rebar object and tools
#  This module provides tools to build Rebar objects.
#  Rebars (or Reinforcing Bars) are metallic bars placed
#  inside concrete structures to reinforce them.
__title__="FreeCAD Rebar"
__author__ = "Yorik van Havre"
__url__ = "http://www.freecadweb.org"
def makeRebar(baseobj=None,sketch=None,diameter=None,amount=1,offset=None,name="Rebar"):
    """makeRebar([baseobj,sketch,diameter,amount,offset,name]): adds a Reinforcement Bar object
    to the given structural object, using the given sketch as profile."""
    if not FreeCAD.ActiveDocument:
        FreeCAD.Console.PrintError("No active document. Aborting\n")
        return
    p = FreeCAD.ParamGet("User parameter:BaseApp/Preferences/Mod/Arch")
    obj = FreeCAD.ActiveDocument.addObject("Part::FeaturePython","Rebar")
    obj.Label = translate("Arch",name)
    _Rebar(obj)
    if FreeCAD.GuiUp:
        _ViewProviderRebar(obj.ViewObject)
    if baseobj and sketch:
        if hasattr(sketch,"Support"):
            if sketch.Support:
                if isinstance(sketch.Support,tuple):
                    if sketch.Support[0] == baseobj:
                        sketch.Support = None
                elif sketch.Support == baseobj:
        obj.Base = sketch
        if FreeCAD.GuiUp:
            sketch.ViewObject.hide()
        obj.Host = baseobj
    if diameter:
        obj.Diameter = diameter
    else:
        obj.Diameter = p.GetFloat("RebarDiameter",6)
    obj.Amount = amount
    obj.Document.recompute()
    if offset != None:
        obj.OffsetStart = offset
        obj.OffsetEnd = offset
    else:
        obj.OffsetStart = p.GetFloat("RebarOffset",30)
        obj.OffsetEnd = p.GetFloat("RebarOffset",30)
    return obj
class _CommandRebar:
    "the Arch Rebar command definition"
    def GetResources(self):
        return {'Pixmap'  : 'Arch_Rebar',
                'MenuText': QT_TRANSLATE_NOOP("Arch_Rebar","Custom Rebar"),
                'Accel': "R, B",
                'ToolTip': QT_TRANSLATE_NOOP("Arch_Rebar","Creates a Reinforcement bar from the selected face of a structural object")}
    def IsActive(self):
        return not FreeCAD.ActiveDocument is None
    def Activated(self):
        sel = FreeCADGui.Selection.getSelectionEx()
        if sel:
            obj = sel[0].Object
            if Draft.getType(obj) == "Structure":
                if len(sel) > 1:
                    sk = sel[1].Object
                    if sk.isDerivedFrom("Part::Feature"):
                        if len(sk.Shape.Wires) == 1:
                            # we have a base object and a sketch: create the rebar now
                            FreeCAD.ActiveDocument.openTransaction(translate("Arch","Create Rebar"))
                            FreeCADGui.addModule("Arch")
                            FreeCADGui.doCommand("Arch.makeRebar(FreeCAD.ActiveDocument."+obj.Name+",FreeCAD.ActiveDocument."+sk.Name+")")
                            FreeCAD.ActiveDocument.commitTransaction()
                            FreeCAD.ActiveDocument.recompute()
                            return
                else:
                    # we have only a base object: open the sketcher
                    FreeCADGui.activateWorkbench("SketcherWorkbench")
                    FreeCADGui.runCommand("Sketcher_NewSketch")
                    FreeCAD.ArchObserver = ArchComponent.ArchSelectionObserver(obj,FreeCAD.ActiveDocument.Objects[-1],hide=False,nextCommand="Arch_Rebar")
                    FreeCADGui.Selection.addObserver(FreeCAD.ArchObserver)
                    return
            elif obj.isDerivedFrom("Part::Feature"):
                if len(obj.Shape.Wires) == 1:
                # we have only the sketch: extract the base object from it
                    if hasattr(obj,"Support"):
                        if obj.Support:
                            if len(obj.Support) != 0:
                                sup = obj.Support[0][0]
                            else:
                                print("Arch: error: couldn't extract a base object")
                                return
                            FreeCADGui.doCommand("Arch.makeRebar(FreeCAD.ActiveDocument."+sup.Name+",FreeCAD.ActiveDocument."+obj.Name+")")
                            return
                        else:
                            return
        FreeCAD.Console.PrintMessage(translate("Arch","Please select a base face on a structural object")+"\n")
        FreeCADGui.Control.closeDialog()
        FreeCADGui.Control.showDialog(ArchComponent.SelectionTaskPanel())
        FreeCAD.ArchObserver = ArchComponent.ArchSelectionObserver(nextCommand="Arch_Rebar")
class _Rebar(ArchComponent.Component):
    "A parametric reinforcement bar (rebar) object"
    def __init__(self,obj):
        ArchComponent.Component.__init__(self,obj)
        self.setProperties(obj)
        obj.IfcRole = "Reinforcing Bar"
    def setProperties(self,obj):
        pl = obj.PropertiesList
        if not "Diameter" in pl:
            obj.addProperty("App::PropertyLength","Diameter","Rebar",QT_TRANSLATE_NOOP("App::Property","The diameter of the bar"))
        if not "OffsetStart" in pl:
            obj.addProperty("App::PropertyLength","OffsetStart","Rebar",QT_TRANSLATE_NOOP("App::Property","The distance between the border of the beam and the first bar (concrete cover)."))
        if not "OffsetEnd" in pl:
            obj.addProperty("App::PropertyLength","OffsetEnd","Rebar",QT_TRANSLATE_NOOP("App::Property","The distance between the border of the beam and the last bar (concrete cover)."))
        if not "Amount" in pl:
            obj.addProperty("App::PropertyInteger","Amount","Rebar",QT_TRANSLATE_NOOP("App::Property","The amount of bars"))
        if not "Spacing" in pl:
            obj.addProperty("App::PropertyLength","Spacing","Rebar",QT_TRANSLATE_NOOP("App::Property","The spacing between the bars"))
            obj.setEditorMode("Spacing", 1)
        if not "Distance" in pl:
            obj.addProperty("App::PropertyLength","Distance","Rebar",QT_TRANSLATE_NOOP("App::Property","The total distance to span the rebars over. Keep 0 to automatically use the host shape size."))
        if not "Direction" in pl:
            obj.addProperty("App::PropertyVector","Direction","Rebar",QT_TRANSLATE_NOOP("App::Property","The direction to use to spread the bars. Keep (0,0,0) for automatic direction."))
        if not "Rounding" in pl:
            obj.addProperty("App::PropertyFloat","Rounding","Rebar",QT_TRANSLATE_NOOP("App::Property","The fillet to apply to the angle of the base profile. This value is multiplied by the bar diameter."))
        if not "PlacementList" in pl:
            obj.addProperty("App::PropertyPlacementList","PlacementList","Rebar",QT_TRANSLATE_NOOP("App::Property","List of placement of all the bars"))
        if not "Host" in pl:
            obj.addProperty("App::PropertyLink","Host","Rebar",QT_TRANSLATE_NOOP("App::Property","The structure object that hosts this rebar"))
        if not "CustomSpacing" in pl:
            obj.addProperty("App::PropertyString", "CustomSpacing", "Rebar", QT_TRANSLATE_NOOP("App::Property","The custom spacing of rebar"))
        if not "Length" in pl:
            obj.addProperty("App::PropertyDistance", "Length", "Rebar", QT_TRANSLATE_NOOP("App::Property","Length of a single rebar"))
            obj.setEditorMode("Length", 1)
        if not "TotalLength" in pl:
            obj.addProperty("App::PropertyDistance", "TotalLength", "Rebar", QT_TRANSLATE_NOOP("App::Property","Total length of all rebars"))
            obj.setEditorMode("TotalLength", 1)
        self.Type = "Rebar"
    def onDocumentRestored(self,obj):
        ArchComponent.Component.onDocumentRestored(self,obj)
    def getBaseAndAxis(self,wire):
        "returns a base point and orientation axis from the base wire"
        import DraftGeomUtils
        if wire:
            e = wire.Edges[0]
            #v = DraftGeomUtils.vec(e).normalize()
            v = e.tangentAt(e.FirstParameter)
            return e.Vertexes[0].Point,v
        if obj.Base:
            if obj.Base.Shape:
                if obj.Base.Shape.Wires:
                    e = obj.Base.Shape.Wires[0].Edges[0]
        return None,None
    def getRebarData(self,obj):
        if not obj.Host:
            return
        if Draft.getType(obj.Host) != "Structure":
            return
        if not obj.Host.Shape:
            return
        if not obj.Base:
            return
        if not obj.Base.Shape:
            return
        if not obj.Base.Shape.Wires:
            return
        if not obj.Diameter.Value:
            return
        if not obj.Amount:
            return
        father = obj.Host
        wire = obj.Base.Shape.Wires[0]
        if Draft.getType(obj.Base) == "Wire": # Draft Wires can have "wrong" placement
            axis = DraftGeomUtils.getNormal(obj.Base.Shape)
        else:
            axis = obj.Base.Placement.Rotation.multVec(FreeCAD.Vector(0,0,-1))
        size = (ArchCommands.projectToVector(father.Shape.copy(),axis)).Length
        if hasattr(obj,"Direction"):
            if not DraftVecUtils.isNull(obj.Direction):
                axis = FreeCAD.Vector(obj.Direction)
                axis.normalize()
        if hasattr(obj,"Distance"):
            if obj.Distance.Value:
                size = obj.Distance.Value
        if hasattr(obj,"Rounding"):
            if obj.Rounding:
                radius = obj.Rounding * obj.Diameter.Value
                wire = DraftGeomUtils.filletWire(wire,radius)
        wires = []
        if obj.Amount == 1:
            offset = DraftVecUtils.scaleTo(axis,size/2)
            wire.translate(offset)
            wires.append(wire)
        else:
            if obj.OffsetStart.Value:
                baseoffset = DraftVecUtils.scaleTo(axis,obj.OffsetStart.Value)
            else:
                baseoffset = None
            if obj.ViewObject.RebarShape == "Stirrup":
                interval = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value + obj.Diameter.Value)
            else:
                interval = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
            interval = interval / (obj.Amount - 1)
            vinterval = DraftVecUtils.scaleTo(axis,interval)
            for i in range(obj.Amount):
                if i == 0:
                    if baseoffset:
                        wire.translate(baseoffset)
                    wires.append(wire)
                else:
                    wire = wire.copy()
                    wire.translate(vinterval)
                    wires.append(wire)
        return [wires,obj.Diameter.Value/2]
    def onChanged(self,obj,prop):
        if prop == "Host":
            if hasattr(obj,"Host"):
                if obj.Host:
                    # mark host to recompute so it can detect this object
                    obj.Host.touch()
    def execute(self,obj):
        if self.clone(obj):
            return
        if not obj.Base:
            return
            return
            return
            return
        if not obj.Amount:
            return
        father = obj.Host
        fathershape = None
        if not father:
            # support for old-style rebars
            if obj.InList:
                if hasattr(obj.InList[0],"Armatures"):
                    if obj in obj.InList[0].Armatures:
                        father = obj.InList[0]
        if father:
            if father.isDerivedFrom("Part::Feature"):
                fathershape = father.Shape
            #print(obj.Rounding)
            if obj.Rounding:
        bpoint, bvec = self.getBaseAndAxis(wire)
        if not bpoint:
            return
        if fathershape:
            size = (ArchCommands.projectToVector(fathershape.copy(),axis)).Length
        else:
            size = 1
                axis.normalize()
                if fathershape:
                else:
                    size = 1
        spacinglist = None
        if hasattr(obj, "CustomSpacing"):
            if obj.CustomSpacing:
                spacinglist = strprocessOfCustomSpacing(obj.CustomSpacing)
                influenceArea = sum(spacinglist) - spacinglist[0] / 2 - spacinglist[-1] / 2
        if (obj.OffsetStart.Value + obj.OffsetEnd.Value) > size:
            return
        # all tests ok!
        if hasattr(obj, "Length"):
            length = getLengthOfRebar(obj)
            if length:
                obj.Length = length
        pl = obj.Placement
        import Part
        circle = Part.makeCircle(obj.Diameter.Value/2,bpoint,bvec)
        circle = Part.Wire(circle)
        try:
            bar = wire.makePipeShell([circle],True,False,2)
            basewire = wire.copy()
        except Part.OCCError:
            print("Arch: error sweeping rebar profile along the base sketch")
            return
        # building final shape
        shapes = []
        placementlist = []
        self.wires = []
        rot = FreeCAD.Rotation()
        if obj.Amount == 1:
            barplacement = CalculatePlacement(obj.Amount, 1, obj.Diameter.Value, size, axis, rot, obj.OffsetStart.Value, obj.OffsetEnd.Value, obj.ViewObject.RebarShape)
            placementlist.append(barplacement)
            if hasattr(obj,"Spacing"):
                obj.Spacing = 0
        else:
            else:
                baseoffset = None
            else:
                barplacement = CalculatePlacement(obj.Amount, i+1, obj.Diameter.Value, size, axis, rot, obj.OffsetStart.Value, obj.OffsetEnd.Value, obj.ViewObject.RebarShape)
                obj.Spacing = interval
        # Calculate placement of bars from custom spacing.
        if spacinglist:
            placementlist[:] = []
                reqInfluenceArea = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value + obj.Diameter.Value)
            else:
                reqInfluenceArea = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
            # Avoid unnecessary checks to pass like. For eg.: when we have values
            # like influenceArea is 100.00001 and reqInflueneArea is 100
            if round(influenceArea) > round(reqInfluenceArea):
                FreeCAD.Console.PrintWarning("Influence area of rebars is greater than "+ str(reqInfluenceArea) + ".\n")
            elif round(influenceArea) < round(reqInfluenceArea):
                FreeCAD.Console.PrintWarning("Last span is greater that end offset.\n")
            for i in range(len(spacinglist)):
                if i == 0:
                    barplacement = CustomSpacingPlacement(spacinglist, 1, axis, father.Placement.Rotation, obj.OffsetStart.Value, obj.OffsetEnd.Value)
                else:
                    barplacement = CustomSpacingPlacement(spacinglist, i+1, axis, father.Placement.Rotation, obj.OffsetStart.Value, obj.OffsetEnd.Value)
            obj.Amount = len(spacinglist)
            obj.Spacing = 0
        obj.PlacementList = placementlist
        for i in range(len(obj.PlacementList)):
            if i == 0:
                bar.Placement = obj.PlacementList[i]
                shapes.append(bar)
                basewire.Placement = obj.PlacementList[i]
                self.wires.append(basewire)
            else:
                bar = bar.copy()
                shapes.append(bar)
                w = basewire.copy()
                w.Placement = obj.PlacementList[i]
                self.wires.append(w)
        if shapes:
            obj.Shape = Part.makeCompound(shapes)
            obj.Placement = pl
        obj.TotalLength = obj.Length * len(obj.PlacementList)
class _ViewProviderRebar(ArchComponent.ViewProviderComponent):
    "A View Provider for the Rebar object"
    def __init__(self,vobj):
        ArchComponent.ViewProviderComponent.__init__(self,vobj)
        self.setProperties(vobj)
        vobj.ShapeColor = ArchCommands.getDefaultColor("Rebar")
    def setProperties(self,vobj):
        pl = vobj.PropertiesList
        if not "RebarShape" in pl:
            vobj.addProperty("App::PropertyString","RebarShape","Rebar",QT_TRANSLATE_NOOP("App::Property","Shape of rebar")).RebarShape
            vobj.setEditorMode("RebarShape",2)
    def onDocumentRestored(self,vobj):
    def getIcon(self):
        import Arch_rc
        return ":/icons/Arch_Rebar_Tree.svg"
    def setEdit(self, vobj, mode):
        if mode == 0:
            if vobj.RebarShape:
                try:
                    # Import module of RebarShape
                    module = __import__(vobj.RebarShape)
                except ImportError:
                    FreeCAD.Console.PrintError("Unable to import RebarShape module\n")
                    return
                module.editDialog(vobj)
    def updateData(self,obj,prop):
        if prop == "Shape":
            if hasattr(self,"centerline"):
                if self.centerline:
                    self.centerlinegroup.removeChild(self.centerline)
            if hasattr(obj.Proxy,"wires"):
                if obj.Proxy.wires:
                    from pivy import coin
                    import re,Part
                    self.centerline = coin.SoSeparator()
                    comp = Part.makeCompound(obj.Proxy.wires)
                    pts = re.findall("point \[(.*?)\]",comp.writeInventor().replace("\n",""))
                    pts = [p.split(",") for p in pts]
                    for pt in pts:
                        ps = coin.SoSeparator()
                        plist = []
                        for p in pt:
                            c = []
                            for pstr in p.split(" "):
                                if pstr:
                                    c.append(float(pstr))
                            plist.append(c)
                        coords = coin.SoCoordinate3()
                        coords.point.setValues(plist)
                        ps.addChild(coords)
                        ls = coin.SoLineSet()
                        ls.numVertices = -1
                        ps.addChild(ls)
                        self.centerline.addChild(ps)
                    self.centerlinegroup.addChild(self.centerline)
        ArchComponent.ViewProviderComponent.updateData(self,obj,prop)
    def attach(self,vobj):
        self.centerlinegroup = coin.SoSeparator()
        self.centerlinegroup.setName("Centerline")
        self.centerlinecolor = coin.SoBaseColor()
        self.centerlinestyle = coin.SoDrawStyle()
        self.centerlinegroup.addChild(self.centerlinecolor)
        self.centerlinegroup.addChild(self.centerlinestyle)
        vobj.addDisplayMode(self.centerlinegroup,"Centerline")
        ArchComponent.ViewProviderComponent.attach(self,vobj)
    def onChanged(self,vobj,prop):
        if (prop == "LineColor") and hasattr(vobj,"LineColor"):
            if hasattr(self,"centerlinecolor"):
                c = vobj.LineColor
                self.centerlinecolor.rgb.setValue(c[0],c[1],c[2])
        elif (prop == "LineWidth") and hasattr(vobj,"LineWidth"):
            if hasattr(self,"centerlinestyle"):
                self.centerlinestyle.lineWidth = vobj.LineWidth
        ArchComponent.ViewProviderComponent.onChanged(self,vobj,prop)
    def getDisplayModes(self,vobj):
        modes=["Centerline"]
        return modes+ArchComponent.ViewProviderComponent.getDisplayModes(self,vobj)
def CalculatePlacement(baramount, barnumber, bardiameter, size, axis, rotation, offsetstart, offsetend, RebarShape = ""):
    """ CalculatePlacement([baramount, barnumber, bardiameter, size, axis, rotation, offsetstart, offsetend]):
    Calculate the placement of the bar from given values."""
    if baramount == 1:
        interval = offsetstart
    else:
        if RebarShape == "Stirrup":
            interval = size - (offsetstart + offsetend + bardiameter)
        else:
            interval = size - (offsetstart + offsetend)
        interval = interval / (baramount - 1)
    bardistance = (interval * (barnumber - 1)) + offsetstart
    barplacement = DraftVecUtils.scaleTo(axis, bardistance)
    placement = FreeCAD.Placement(barplacement, rotation)
    return placement
def CustomSpacingPlacement(spacinglist, barnumber, axis, rotation, offsetstart, offsetend):
    """ CustomSpacingPlacement(spacinglist, barnumber, axis, rotation, offsetstart, offsetend):
    Calculate placement of the bar from custom spacing list."""
    if barnumber == 1:
        bardistance = offsetstart
    else:
        bardistance = sum(spacinglist[0:barnumber])
        bardistance = bardistance - spacinglist[0] / 2
        bardistance = bardistance - spacinglist[barnumber - 1] / 2
        bardistance = bardistance + offsetstart
    return placement
def strprocessOfCustomSpacing(span_string):
    """ strprocessOfCustomSpacing(span_string): This function take input
    in specific syntax and return output in the form of list. For eg.
    Input: "3@100+2@200+3@100"
    Output: [100, 100, 100, 200, 200, 100, 100, 100]"""
    # import string
    span_st = span_string.strip()
    span_sp = span_st.split('+')
    index = 0
    spacinglist = []
    while index < len(span_sp):
        # Find "@" recursively in span_sp array.
        # If not found, append the index value to "spacinglist" array.
        if span_sp[index].find('@') == -1:
            spacinglist.append(float(span_sp[index]))
        else:
            in_sp = span_sp[index].split('@')
            count = 0
            while count < int(in_sp[0]):
                spacinglist.append(float(in_sp[1]))
                count += 1
        index += 1
    return spacinglist
def getLengthOfRebar(rebar):
    """ getLengthOfRebar(RebarObject): Calculates the length of the rebar."""
    base = rebar.Base
    # When rebar is derived from DWire
    if hasattr(base, "Length"):
        return base.Length
    # When rebar is derived from Sketch
    elif base.isDerivedFrom("Sketcher::SketchObject"):
        length = 0
        for geo in base.Geometry:
            length += geo.length()
        return length
    else:
        FreeCAD.Console.PrintError("Cannot calculate rebar length from its base object\n")
        return None
if FreeCAD.GuiUp:
    FreeCADGui.addCommand('Arch_Rebar',_CommandRebar())
And git diff between original file and modified file is:
diff --git a/ArchRebar.py b/ArchRebar.py
index 5a47162..193f691 100644
--- a/ArchRebar.py
+++ b/ArchRebar.py
@@ -82,7 +82,7 @@ def makeRebar(baseobj=None,sketch=None,diameter=None,amount=1,offset=None,name="
     obj.Amount = amount
-    if offset:
+    if offset != None:
     else:
@@ -272,7 +272,10 @@ class _Rebar(ArchComponent.Component):
             else:
                 baseoffset = None
-            interval = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
+            if obj.ViewObject.RebarShape == "Stirrup":
+                interval = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value + obj.Diameter.Value)
+            else:
+                interval = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
@@ -374,7 +377,7 @@ class _Rebar(ArchComponent.Component):
         self.wires = []
         if obj.Amount == 1:
-            barplacement = CalculatePlacement(obj.Amount, 1, size, axis, rot, obj.OffsetStart.Value, obj.OffsetEnd.Value)
+            barplacement = CalculatePlacement(obj.Amount, 1, obj.Diameter.Value, size, axis, rot, obj.OffsetStart.Value, obj.OffsetEnd.Value, obj.ViewObject.RebarShape)
                 obj.Spacing = 0
@@ -383,17 +386,23 @@ class _Rebar(ArchComponent.Component):
             else:
                 baseoffset = None
+            else:
-                barplacement = CalculatePlacement(obj.Amount, i+1, size, axis, rot, obj.OffsetStart.Value, obj.OffsetEnd.Value)
+                barplacement = CalculatePlacement(obj.Amount, i+1, obj.Diameter.Value, size, axis, rot, obj.OffsetStart.Value, obj.OffsetEnd.Value, obj.ViewObject.RebarShape)
         if spacinglist:
-            reqInfluenceArea = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
+                reqInfluenceArea = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value + obj.Diameter.Value)
+            else:
+                reqInfluenceArea = size - (obj.OffsetStart.Value + obj.OffsetEnd.Value)
@@ -527,14 +536,17 @@ class _ViewProviderRebar(ArchComponent.ViewProviderComponent):
-def CalculatePlacement(baramount, barnumber, size, axis, rotation, offsetstart, offsetend):
+def CalculatePlacement(baramount, barnumber, bardiameter, size, axis, rotation, offsetstart, offsetend, RebarShape = ""):
-    """ CalculatePlacement([baramount, barnumber, size, axis, rotation, offsetstart, offsetend]):
+    """ CalculatePlacement([baramount, barnumber, bardiameter, size, axis, rotation, offsetstart, offsetend]):
     if baramount == 1:
     else:
-        interval = size - (offsetstart + offsetend)
+        if RebarShape == "Stirrup":
+            interval = size - (offsetstart + offsetend + bardiameter)
+        else:
+            interval = size - (offsetstart + offsetend)
After modification, with same data, the stirrup in column looks like:
Please check if above solution is right and give your suggestions.
Thanks,
