Today, I added support for LShaped rebars and here is the code:Suraj Dadral wrote: ↑Mon Apr 08, 2019 10:46 am I created a simple function for Single Tie Column Reinforcement and can be found here:
https://github.com/SurajDadral/FreeCAD- ... ngleTie.py
Currently, this will create:
- Straight rebars and not L-shaped rebars.
I will add support for them soon.
import FreeCADGui
import sys
sys.path.append("../")
from Stirrup import makeStirrup
from StraightRebar import makeStraightRebar
from LShapeRebar import makeLShapeRebar
from Rebarfunc import getParametersOfFace
def singleTieColumn1Reinforcement(
xdir_cover,
ydir_cover,
offset_of_tie,
bentAngle,
bentFactor,
dia_of_tie,
amount_spacing_check,
amount_spacing_value,
dia_of_rebars,
t_offset_of_rebars,
b_offset_of_rebars,
rebar_type="StraightRebar",
l_rebar_orientation="Top Inside",
l_rebar_rounding=None,
l_part_length=None,
structure=None,
""" singleTieColumn1Reinforcement(XDirectionCover, YDirectionCover,
OffsetOfTie, BentAngle, BentFactor, DiameterOfTie, AmountSpacingCheck,
AmountSpacingValue, DiameterOfRebars, RebarType, LShapeRebarOrientation,
LShapeRebarRounding, LShapePartLength, Structure)
Adds the Single Tie reinforcement to the selected structural column
object.
It takes four different orientations input for L-shaped rebars i.e. 'Top
Inside', 'Top Outside', 'Bottom Inside', 'Bottom Outside'.
if not structure:
selected_obj = FreeCADGui.Selection.getSelectionEx()[0]
structure = selected_obj.Object
# Calculate common parameters for Straight/LShaped rebars
f_cover = xdir_cover + dia_of_rebars / 2 + dia_of_tie / 2
t_cover = t_offset_of_rebars
b_cover = b_offset_of_rebars
rebar_amount_spacing_check = True
rebar_amount_spacing_value = 2
# facename = "Face2"
# find facename of face perpendicular to x-axis
index = 1
faces = structure.Shape.Faces
for face in faces:
normal = face.normalAt(0, 0)
if normal.x == 1 and normal.y == 0 and normal.z == 0:
facename = "Face" + str(index)
index += 1
# Create Straight Rebars
if rebar_type == "StraightRebar":
rl_cover = ydir_cover + dia_of_rebars / 2 + dia_of_tie / 2
orientation = "Vertical"
list_coverAlong = ["Right Side", "Left Side"]
for coverAlong in list_coverAlong:
makeStraightRebar(
f_cover,
(coverAlong, rl_cover),
t_cover,
b_cover,
dia_of_rebars,
rebar_amount_spacing_check,
rebar_amount_spacing_value,
orientation,
structure,
facename,
# Create L-Shaped Rebars
elif rebar_type == "LShapeRebar":
FacePRM = getParametersOfFace(structure, facename)
face_length = FacePRM[0][0]
if not l_part_length:
l_part_length = (face_length - 2 * ydir_cover) / 3
if not l_rebar_rounding:
l_rebar_rounding = (float(dia_of_tie) / 2 + dia_of_rebars / 2) / dia_of_tie
if (
l_rebar_orientation == "Top Inside"
or l_rebar_orientation == "Bottom Inside"
l_cover = []
r_cover = []
l_cover.append(ydir_cover + dia_of_rebars / 2 + dia_of_tie / 2)
r_cover.append(
face_length
- l_part_length
- ydir_cover
- dia_of_tie / 2
- dia_of_rebars / 2
l_cover.append(r_cover[0])
r_cover.append(l_cover[0])
# Assign orientation value
if l_rebar_orientation == "Top Inside":
list_orientation = ["Top Left", "Top Right"]
else:
list_orientation = ["Bottom Left", "Bottom Right"]
elif (
l_rebar_orientation == "Top Outside"
or l_rebar_orientation == "Bottom Outside"
if l_rebar_orientation == "Top Outside":
else:
l_cover = []
r_cover = []
r_cover.append(
face_length
- ydir_cover
- dia_of_tie / 2
- dia_of_rebars / 2
+ l_part_length
i = 0
for orientation in list_orientation:
makeLShapeRebar(
f_cover,
b_cover,
l_cover[i],
r_cover[i],
dia_of_rebars,
t_cover,
l_rebar_rounding,
orientation,
structure,
facename,
i += 1
# Calculate parameters for Stirrup
l_cover = r_cover = xdir_cover
t_cover = b_cover = ydir_cover
f_cover = offset_of_tie
# facename = "Face6"
# find facename of face perpendicular to z-axis
index = 1
for face in faces:
if normal.x == 0 and normal.y == 0 and normal.z == 1:
index += 1
# Create Stirrups
makeStirrup(
l_cover,
r_cover,
t_cover,
b_cover,
f_cover,
bentAngle,
bentFactor,
dia_of_tie,
rounding,
structure,
facename,
Supported orientations for L-Shaped rebars:
- Top Inside
- Top Outside
- Bottom Inside
- Bottom Outside
Please review and give your suggestions.
Regards
