Automate Reinforcement GSoC proposal
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Postby Suraj Dadral » Sun Jul 21, 2019 7:52 am
amrit3701 wrote:
Thu Jul 18, 2019 1:40 pm
I think bent angle and extension factor should be same for all ties in the column because all ties have same diameter.
I have set these parameters equal for all ties as in commits: commit1, commit2
I have created functions to create and edit TwoTiesSixRebars column reinforcement. commit
Now user can create TwoTiesSixRebars column reinforcement through UI.
I will enable editing of TwoTiesSixRebars column reinforcement through UI by today.
After that I will create user documentation for the work done upto now.
Please give your suggestions.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Mon Jul 22, 2019 4:05 am
Hello everyone,
I have completed creating and editing of TwoTiesSixRebars column reinforcement through UI.
commit
Example output:
Please test it and let me know if you want any changes.
Now, I will write documentation for TwoTiesSixRebars and Circular column reinforcement.
Thanks,
amrit3701
Postby amrit3701 » Mon Jul 22, 2019 4:21 pm
Hello everyone,
commit
Hi @Suraj,
I have reviewed and test your code. Everything is good.
Some suggestions:
  • I saw that you are using `print` function to show warnings or errors to user. `print` statement not print anything in FreeCAD console and in the status bar. In FreeCAD, we have some special methods do that job.
    For eg,
    FreeCAD.Console.PrintMessage("Some message.\n")
    FreeCAD.Console.PrintWarning("To warn the user.\n")
    FreeCAD.Console.PrintError("Error message.\n")
    Don't forget to add `\n` at the end of the message.
  • It will be good if you add an image for two ties six rebar column reinforcement in the dialog box.
As your second evaluation is closer, I suggest you write a short summary like what is done and pending.
Suraj Dadral
Postby Suraj Dadral » Tue Jul 23, 2019 6:14 pm
Hi @Suraj,
Thanks @amrit3701
Some suggestions:
    For eg,
Done as you suggested here: https://github.com/amrit3701/FreeCAD-Re ... -264891401
commit: https://github.com/SurajDadral/FreeCAD- ... 9bbcfdf2ed
Done: https://github.com/SurajDadral/FreeCAD- ... 85daa934ad
In first coding phase:
- Implemented SingleTieFourRebars and SingleTieMultipleRebars column reinforcement.
- Created user documentation.
In second coding phase:
- Implemented circular column reinforcement.
- Implemented TwoTiesSixRebars column reinforcement.
Pending work:
- Implement beam reinforcement.
- Implement master configuration file for rebar addon.
- Create user documentation.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Sun Jul 28, 2019 7:49 am
Hello everyone,
I was unable to interact from few days due to some health related issue. Now, I am fine to work.
I have created user documentation for work done till now.
Documentation page for TwoTiesSixRebars Column Reinforcement: https://www.freecadweb.org/wiki/Arch_Re ... sSixRebars
Documentation page for Circular Column Reinforcement: https://www.freecadweb.org/wiki/Arch_Re ... nforcement
Please review and give your suggestions.
Now, I will start creating beam reinforcement.
Thanks,
amrit3701
Postby amrit3701 » Sun Jul 28, 2019 5:32 pm
Nice work! Please share all things which we discussed in the yesterday's meeting. I don't want to do all things in this GSoC but if everything is documented then it will be great. ;) One thing more, also write all the assumptions which we assume that user should know while creating reinforcinment with addon. For eg, which staretegy we are using when creating rebars with spacing and what happens when user enter wrong value of spacing.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Mon Jul 29, 2019 6:09 pm
Nice work!
Thanks :D
Yesterday me, @amrit3701, @hardeeprai and some civil engineer students discussed about the project, and here is summary of discussion:
  • Default value of extension factor of ties should be 10.
  • Bent angle of two ties in column reinforcement can be different.
  • LShape rebars should bend towards (or opposite to) center of column in case of column reinforcement.
  • Helical rebars should become horizontal or should bend towards center of circle at end, and will complete one more circle after it became horizontal, just like spring.
  • Specify about offset end in case when rebars are made by giving spacing value for rebars instead of giving number of rebars.
  • It is better if user will be able to specify formula for hook extension in ui instead of directly giving its value.
  • Create LShape rebars in circular column.
  • When we created circular column reinforcement with angle between rebars equal to 17°, then two rebars overlapped each other. I need to fix this.
    According to suggestion by @hardeeprai, the spacing between straight rebars in case of circular column will always remains same. So, if user specifies angle which will not divide 360 completely, e.g. 17°, then first we needs to calculate number of rebars = math.ceil(360 / angle)
    e.g. number of rebars = math.ceil(360 / 17) = 22
    then we need to calculate angle again as angle = 360 / number of rebars
    e.g. angle = 360 / 22
    angle = 16°
    Now, we need to create straight rebars with angle between them equal to 16°.
Yes, I will try to finish beam reinforcement as soon as I can.
Then, I will create user and developer documentation.
I will take care of this while creating documentation. I will create separate page for these assumptions.
@All community members, please review and give your suggestions.
Thanks,
Suraj Dadral
Postby Suraj Dadral » Thu Aug 01, 2019 5:03 pm
Hello everyone,
I have created function to create straight rebars in top and bottom beam reinforcement.
commits: commit1, commit2.
Sample output:
from BeamReinforcement import TwoLeggedBeam
TwoLeggedBeam.makeReinforcement(40, 40, 40, 40, 20, 135, 10, 8, True, 5, ("2#20mm@40mm+2#16mm@200mm+2#20mm@40mm", "4#16mm@50mm"), [("StraightRebar", "StraightRebar", "StraightRebar"), ("StraightRebar")], 25, ("2#20mm@40mm+2#16mm@200mm+2#20mm@40mm", "4#16mm@50mm"), [("StraightRebar", "StraightRebar", "StraightRebar"), ("StraightRebar")], 25, "3#16mm@50mm", "StraightRebar", 40, "3#16mm@50mm", "StraightRebar", 40)
Now, I will add support for LShaped rebars in beam reinforcement.
Thanks,
beam.FCStd
(54.14 KiB) Downloaded 27 times
Suraj Dadral
Postby Suraj Dadral » Sat Aug 03, 2019 4:56 pm
Hello everyone,
I have completed function to create beam reinforcement. And can be found here: https://github.com/SurajDadral/FreeCAD- ... eam.py#L45
Example Output:
TwoLeggedBeam.makeReinforcement(40, 40, 40, 40, 20, 135, 10, 8, True, 5, ("2#20mm@40mm+2#16mm@-100mm+2#20mm@40mm", "3#16mm@50mm"), [("StraightRebar", "LShapeRebar", "StraightRebar"), ("StraightRebar")], 25, ("2#20mm@40mm+2#16mm@-100mm+2#20mm@40mm", "3#16mm@50mm"), [("StraightRebar", "LShapeRebar", "StraightRebar"), ("StraightRebar")], 25, "1#20mm@50mm+1#16mm@-100mm+1#20mm@50", ("StraightRebar", "LShapeRebar", "StraightRebar"), 40, "1#20mm@-50mm+1#16mm@-100mm+1#20mm@-50", ("LShapeRebar", "LShapeRebar", "LShapeRebar"), 40, 2, 100, "Front Outside", 2, 40, "Front Outside", 2, 100, "Rear Outside", (2, 1, 2), (100, 70, 100), ("Front Outside", "Rear Inside", "Front Outside"))
beam.FCStd
(76.43 KiB) Downloaded 30 times
Please check and give your suggestions.
Now, I will add the created rebars under group object and will store their properties.
Thanks,
amrit3701
Postby amrit3701 » Wed Aug 07, 2019 1:58 pm
Looks good! :)
