Automate Reinforcement GSoC proposal
Contributions from the participants, questions and answers to their projects.
Discussions of proposals for upcoming events.
Suraj Dadral
Re: Automate Reinforcement GSoC proposal
Post by Suraj Dadral »
ebrahim raeyat wrote: Sat Aug 31, 2019 2:27 pm
Thanks @Suraj. do you have any plan for multi beam reinforcement? I mean continues beams.
Thanks @ebrahim raeyat. I don't know much about multi beam reinforcement yet. I will be happy do implement this. I will try to get more information about it and will let you know soon.
ebrahim raeyat wrote: Sat Aug 31, 2019 2:27 pm and another question:
I want to produce 2d drafting for concrete structures, like in my pyconcrete github. do you think i can use your work for this goal or i must work from scratch? till now i can give some parameters from user and produce 2D beam drawing, but i want to first bring this drafting in freecad and let user to modify some parameters and then export it to dxf or dwg format.
related topic: automation if design
I will first read your provided links and will then let you know.
Thanks,
Suraj Dadral
bitacovir wrote: Sun Jan 19, 2020 1:52 pm Is it available this automate reinforcement?
I just installed the rebar addon and these are not present in the list of options.
These new tools are now available in rebar addon.
Try updating rebar addon from addon manager.
Thanks,
bitacovir
Post by bitacovir »
Suraj Dadral wrote: Wed Mar 11, 2020 1:55 pm
Thanks,
Thank you :)
::bitacovir::
Canal Youtube Grupo Telegram de FreeCAD Español
My personal web site
My GitHub repository
Mini Airflow Tunnel Project
bitacovir
Post by bitacovir »
Suraj Dadral. I noticed the icons of the Column and Beam Rebar do not follow FreeCAD Art guidelines. I can give you new icons for your addon, if you want.
Column.svg
(27.3 KiB) Downloaded 91 times
Beam.svg
(24.7 KiB) Downloaded 77 times
Column Icon
Column Icon
Beam Icon
Beam Icon
::bitacovir::
Suraj Dadral
bitacovir wrote: Sat Mar 14, 2020 1:24 am
Thanks @bitacovir. I added your icons and sent PR to @amrit3701 as here: https://github.com/amrit3701/FreeCAD-Re ... nt/pull/40
And also updated icons in FreeCAD wiki:
https://wiki.freecadweb.org/File:Arch_R ... cement.svg
Thanks,
ebrahim raeyat
Post by ebrahim raeyat »
Suraj Dadral wrote: Sun Jan 19, 2020 2:06 pm
Thanks,
Hi @Suraj, did you read my links about continuous beams? I am trying to implement my pyconcrete in FreeCAD. I will be appreciated to look at that
ebrahim raeyat
Hi @Suraj Dadral and others, how do you guys test these codes? exactly I mean how we can apply TDD approach with freecad?
Bance
Post by Bance »
FYI this thread is continued here:-https://forum.freecadweb.org/viewtopic. ... &start=170
Steve.
Suraj Dadral
ebrahim raeyat wrote: Mon Jul 13, 2020 1:44 pm
Thanks,
Hi @ebrahim raeyat,
I apologies for being late as I was focusing on Automated Reinforcement Drawing/Dimensioning as pointed by @Bance.
I had a look at your latest work (on 14 March).
The drawing plan dxf output produced by your code looks marvelous :D.
As we are now moving towards automated drawing/dimensioning of rebars, so we can also utilize your code to generated drawings in dxf format.
Please let me know if I may help you in any way.
Thanks,
Suraj Dadral
ebrahim raeyat wrote: Sat Jul 25, 2020 7:23 am Hi @Suraj Dadral and others, how do you guys test these codes?
As in case of code related to reinforcement, we do manual testing.
ebrahim raeyat wrote: Sat Jul 25, 2020 7:23 am exactly I mean how we can apply TDD approach with freecad?
Not sure, but this maybe helpful: https://wiki.freecadweb.org/Testing
Thanks,
