Yes and no Was thinking to have it open all the time... But it is ok, don't loose time with this, it is not so important and others maybe would not agree with me
BCF Support GSoC Proposal
Re: BCF Support GSoC Proposal
Well as I think about it, this implementation is actually a drop down list
The constant open list is totally doable, but the I think it takes up too much of screen real estate, especially on small screens. On the other hand it could still be done in a vertical way, where the group containing the "open" and "save" button is beside the list of topics. That, I think, would not take up to much vertical space.
I would estimate that it takes just one hour, since it is only changing some lines in the view part of the application, so not that big of a deal . I could show you a draft by tomorrow.
@saso: attached you find my second take on the list of topics to select from. It still needs a little polishing though. But first let's see what other people think of this design
- topicListv2.gif (90.32 KiB) Viewed 8518 times
I also like the idea to see the list of topics in one go... It gives you a quick overview of how deep in the word censored you are with a particular model
Maybe try this: there is a Qt widget that is a kind of resizable frame, (QSplitter I think). You could have two regions, one above and one below, the topics list above and the topic details below, and that would allow the user to drag the splitter, and therefore determine how much space they wish for each...
For the GSOC question, I don't think it is much important in your case, as the work done is clearly visible and well formatted, easy to review, and easy to tell apart from the work done in FreeCAD, as all your work is in its own repo. Just make sure your readme is up to date and gives a short overview of the whole adventure (google people might just look there and not further), and you should be fine...
On the FreeCAD side, regarding packaging: I think you're almost there, I see you added a convenience macro, etc.. I would suggest one thing, which is move the macro to the root of your repo. That should be all that is needed to add it to the addons installer later on (the macro will be picked up and copied to the macros folder automatically).
If you feel like it, I would maybe also add some other goodie: register the .bcf file extension so opening one with FreeCAD would fire up your plugin. Basically you need to add an Init.py file to your repo root, and inside:
bcfImportPlugin being any importable module that contains both an open(filename) and insert(filename,docname) functions. In your case, both can do the same thing since they don't add anything to the document anyway.
Regarding the plugin itself, gave it a test spin today, it's awesome! I have these two little cosmetic suggestions:
Use a vertical spacer to make things look a bit more compact:
Don't use black text Use QtGui.QApplication.palette().text()
App.addImportType("BCF Files (*.bcf)","bcfImportPlugin")
The blue colored text is also harsh in the dark theme
Thank you for your valuable feedback @yorik. Especially the registration of a new import type in FreeCAD seems like a real cool feature for the plugin, I will implement it tomorrow.
Regarding the topic list, instead of the combo box: it will be switched then, to give the developer an impression of (like you said it) "how deep in the word censored he/she is"
The tip with the QSplitter is also really great, that removes some of the burden of rightfully dimensioning all UI elements off of me, thank you!
The thing with the dark theme is ... well I didn't consider a dark theme at all, even though nowadays everyone wants a dark theme for everything. The text colors will be fixed. Thanks for pointing that out @yorik, @amrit3701 and @Kunda1!
Otherwise I think a little update is appropriate at this point:
Except the changes discussed above, I am currently working on a feature that let's you create a complete new project/bcf file. Topics can already be added to an existing project/bcf file. I still have some issues with the size of comments, as it does not get calculated correctly right at the start of the plugin. And this week I am also focusing more on documenting the code and updating the wiki pages and the readme I have written.
Also I have added a little more functionality to the listview listing the additional document references in the "topic metrics" dialog. A double click on an element in either column tries to open the file from disk or copy the path of the file to the clipboard, respectively.
Here the probably last update of GSoC'19, since next week already the final evaluation round is taking place.
I just released the final version of the plugin, you can check it out here.
This release incorporates your suggestions about the text colours, which are not hardcoded anylonger
Not that much has else changed since the last release, though. Attached you will find the release notes file.
Next week I will still be updating the wiki pages, because I didn't get to it this week, apart from adding two new sections to the gui tutorial.
@luzpaz created an issue asking if the repository could already be added to the addons repository of FreeCAD. As of this release I am pretty confident that the plugin complies with the addon manager's requirements. But I am eager to see
- release-notes.txt
- (2.63 KiB) Downloaded 138 times
File "/home/yorik/.FreeCAD/Mod/BCFPlugin/bcfplugin/gui/plugin_view.py", line 213, in setupSplitter
splitter.setOrientation(Qt.Vertical)
<class 'NameError'>: name 'Qt' is not defined
Well done! I'm playing with it now, this is functional, elegant, usable, and I see you paid attention to a lot of smaller usability details already (warning before closing unsaved file, etc..). Very impressive job you did!
The Readme looks okay to me, so I think basically everything is ready for GSOC.
Let's add it to the Addon Manager? That would be the icing on the cake... I don't think there is anything else to be done on your side, the macro will be picked up automatically by the addon manager.
A couple of small cosmetic details more, if you are up to it:
1) the Topic metrics view should have its "stretch last column" property turned on (you can do that in QDesigner)
2) When selecting a comment, it uses white background and the white text is not visible.. I think either you force white background and black text, or you use selected background and selected text color (both should be there somewhere in the QPalette I think)
Hi Yorik, thanks for the feedback!
I also fixed the issue with the topic metrics table, thanks for the suggestion of view.(horizontal|vertical)Header().setStretchLastSection(bool).
But sadly I can't recreate the comment-colour selection issue. I currently have the Arc-Dark theme active and I am using the kvantum-qt5 theme engine. To fix this issue could you tell me which qt theme you are using?
The code selecting the font colour is the following:
Otherwise, I am not setting any colours in for the comment list. Is maybe QApplication.palette() is the wrong instance in this case?
Strangely I didn't get these error messages. Maybe it has todo with the PySide version (5.13.0-2) I am using, that Qt automatically gets imported too, if something is imported from QtCore. Anyways I added Qt explicitly now in the import statement from PySide2.QtCore import (..., Qt, ...)yorik wrote: ↑Fri Aug 16, 2019 5:46 pm Code: Select all
Same in gui/views/viewpointslist.py and snapshotlist.py (I'm using your master branch and not the release). Some "from QtCore import Qt" missing I guess...
elif role == Qt.ForegroundRole:
# set the color if a viewpoint is linked to the comment
link = QApplication.palette().link()
normal = QApplication.palette().text()
brush = normal if item.viewpoint is None else link
return brush
