Boost Libraries v1.70 released
Post by Kunda1 »
looo
Re: Boost Libraries v1.70 released
Post by looo »
some issues with coin3d updated to boost 1.70:
https://github.com/conda-forge/coin3d-feedstock/pull/14
looo
Post by looo »
THe problem with coin was solved by using:
-D Boost_NO_BOOST_CMAKE:BOOL=ON \
Now I am stuck with FreeCAD. Linux has a conda-specific problem with vtk-configuration. On windows a problem with boost-libraries is reported:
https://ci.appveyor.com/project/conda-f ... 8370#L1388
Interpreter.cpp.obj : error LNK2019: unresolved external symbol "private: class boost::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > > & __cdecl boost::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >::do_assign(char const *,char const *,unsigned int)" (?do_assign@?$basic_regex@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@boost@@AEAAAEAV12@PEBD0I@Z) referenced in function "public: __cdecl boost::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >(char const *,unsigned int)" (??0?$basic_regex@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@boost@@QEAA@PEBDI@Z)
Interpreter.cpp.obj : error LNK2019: unresolved external symbol "public: bool __cdecl boost::re_detail_107000::perl_matcher<char const *,class std::allocator<struct boost::sub_match<char const *> >,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >::match(void)" (?match@?$perl_matcher@PEBDV?$allocator@U?$sub_match@PEBD@boost@@@std@@U?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@re_detail_107000@boost@@QEAA_NXZ) referenced in function "bool __cdecl boost::regex_match<char const *,class std::allocator<struct boost::sub_match<char const *> >,char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >(char const *,char const *,class boost::match_results<char const *,class std::allocator<struct boost::sub_match<char const *> > > &,class boost::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > > const &,enum boost::regex_constants::_match_flags)" (??$regex_match@PEBDV?$allocator@U?$sub_match@PEBD@boost@@@std@@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@boost@@YA_NPEBD0AEAV?$match_results@PEBDV?$allocator@U?$sub_match@PEBD@boost@@@std@@@0@AEBV?$basic_regex@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@0@W4_match_flags@regex_constants@0@@Z)
Interpreter.cpp.obj : error LNK2019: unresolved external symbol "private: void __cdecl boost::re_detail_107000::perl_matcher<char const *,class std::allocator<struct boost::sub_match<char const *> >,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >::construct_init(class boost::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > > const &,enum boost::regex_constants::_match_flags)" (?construct_init@?$perl_matcher@PEBDV?$allocator@U?$sub_match@PEBD@boost@@@std@@U?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@re_detail_107000@boost@@AEAAXAEBV?$basic_regex@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@3@W4_match_flags@regex_constants@3@@Z) referenced in function "bool __cdecl boost::regex_match<char const *,class std::allocator<struct boost::sub_match<char const *> >,char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > >(char const *,char const *,class boost::match_results<char const *,class std::allocator<struct boost::sub_match<char const *> > > &,class boost::basic_regex<char,struct boost::regex_traits<char,class boost::w32_regex_traits<char> > > const &,enum boost::regex_constants::_match_flags)" (??$regex_match@PEBDV?$allocator@U?$sub_match@PEBD@boost@@@std@@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@boost@@YA_NPEBD0AEAV?$match_results@PEBDV?$allocator@U?$sub_match@PEBD@boost@@@std@@@0@AEBV?$basic_regex@DU?$regex_traits@DV?$w32_regex_traits@D@boost@@@boost@@@0@W4_match_flags@regex_constants@0@@Z)
bin\FreeCADBase.dll : fatal error LNK1120: 3 unresolved externals
edit: this build uses source for FreeCAD 0.18.2. So it's possible this is already solved in master.
looo
Post by looo »
Is it possible we are not linking against boost/regex which is needed in Interpreter.cpp?
looo
Post by looo »
The previous reported problem for windows was solved by using:
-D Boost_NO_BOOST_CMAKE:BOOL=ON for windows too. But now there is another problem:
%PREFIX%\Library\include\boost/system/detail/system_category_win32.hpp(52): error C2039: '_snprintf': is not a member of 'std'
similar issue here:
https://github.com/boostorg/system/issues/32
looo
Post by looo »
This are the relevant lines for the reported boost-error: https://github.com/boostorg/system/blob ... hpp#L29L56
looo
Post by looo »
After patching vtk-cmake for linux the build works but FreeCAD fails at runtime. Maybe someone knows what the error message means:
ok
libgcc_s.so.1 must be installed for pthread_cancel to work
testAsynchronPrintFromThread (BaseTests.ConsoleTestCase) ... FreeCAD 0.18, Libs: 0.18R16117 (Git)
(c) Juergen Riegel, Werner Mayer, Yorik van Havre 2001-2019
import TestFemCommon
import TestObjectCreate
import TestObjectType
Call from Python thread (not synchronized): count=1
/home/conda/feedstock_root/build_artifacts/freecad_1560942319717/test_tmp/run_test.sh: line 7: 11405 Aborted                 (core dumped) FreeCADCmd -t 0
Founder
Post by wmayer »
One possible reason is that somewhere a Python C function is used without locking the GIL. However, there can be many other reasons for an "abort".
looo
Post by looo »
I think the important information here is:
looo
Post by looo »
linux problem found: I previously added a patch to smesh which result in the reported issue. removing the patch and using sed to remove some wrong paths in the vtk-library resulted in a working smesh-freecad combination. There will be an updated smesh available soon (hopefully) [1]
Now only the windows issue has to be resolved. Somewhere in the headers of the dependencies or in freecad-source itself there must be a definition of _snprintf this somehow conflicts with std::snprintf.
[1] https://github.com/conda-forge/smesh-feedstock/pull/25
