feature request, move surface of object to XY-plane
freecc
Postby freecc » Sat Apr 20, 2019 10:13 pm
I model things and want to 3d print them. Every part has to be moved to the XY plane to be in the correct place in the slicer. So I am requesting this feature. That I can just click on a face and move it to the XY-plane. Put the center of the object on the z axis if it is possible.
NormandC
Re: feature request, move surface of object to XY-plane
Postby NormandC » Sun Apr 21, 2019 3:30 am
I'm pretty sure someone proficient in Python could make a macro for that.
NormandC
Postby NormandC » Sun Apr 21, 2019 4:09 am
Actually, somebody (openBrain) already did! :D
[Macro] Straighten objects
How to use:
  1. Select a face on the solid(s) to move to the XY plane; optionally select an edge as well
  2. Launch the macro
  3. Bam! You're done. ;)
Note: if you are working with a PartDesign Body, you first need to set its "Display Mode Body" property in the View tab from "Through" to "Tip", or it won't work as expected.
freecc
Postby freecc » Sun Apr 21, 2019 1:57 pm
How to use:
  2. Launch the macro
thank you!
openBrain
Postby openBrain » Sun Apr 21, 2019 5:49 pm
How to use:
  2. Launch the macro
Just a precision. The extra edge if used, it will be set parallel to X axis.
[/quote]
[/quote]
@NormandC, do you have an example where the Display Mode Body set to Through leads to issues. The macro normally correctly manages this case. I did some basic testing and got no bug, thus I'll be interested if you have a demo file that fails. ;)
