node editor - pyflow
Re: node editor - pyflow
This looks very promising.
Sorry to be the bearer of bad news but it seems like development on the PyFlow is stalled, last activity on GH is March 2018. It's also not py3 compatible yet.
Edit: my bad, it's the wrong project as pointed out by @looo below
There are two different projects with the same name. We are talking about PyFlow:
https://github.com/IlgarLunin/PyFlow/commits/master
- microelly2
There are multiple libraries with the mname pyflow,Kunda1 wrote: ↑Tue May 14, 2019 10:59 am Sorry to be the bearer of bad news but it seems like development on the PyFlow is stalled, last activity on GH is March 2018. It's also not py3 compatible yet.
what I use is :
ilgar is very active and there is a community around this app too.
the solution uses the qt module as a wrapper for different qt versions, so it runs with the old python2 and the newer python3 too.
Sorry folks, that was my bad. I corrected my post above. Moving on
I downloaded the source and click starterui.bat to run it. But there is a error message:
"AttributeError: 'PySide.QtGui.QScrollArea' object has no attribute 'setSizeAdjustPolicy'"
https://imgur.com/UaemRNJ
I deleted the a line in GraphEditor_ui.py line 100tak wrote: ↑Wed May 22, 2019 3:20 am I downloaded the source and click starterui.bat to run it. But there is a error message:
"self.scrollArea.setSizeAdjustPolicy(QtWidgets.QAbstractScrollArea.AdjustToContents)"
The app can open now.
There is another question. How can I use pyflow in FC like this video?
https://www.youtube.com/watch?v=RO3m7oK3AN8
Please add pictures as attachments and not as links.
- microelly2
My working version is
https://github.com/microelly2/PyFlow/tree/freecad (branch freecad)
I had to deactivate some lines of code to get it running too.
I created a workbench structure with two test actions to start a simple environment
there will be a library with FreeCAD object nodes but I still have to learn the best way for the communication between the FreeCAD objects and the PyFlow nodes.
I Use this sourse. It is working now. But I don't know why there is nothing is propertyViewmicroelly2 wrote: ↑Wed May 22, 2019 7:45 am My working version is
