microelly2 wrote:
node editor - pyflow
Re: node editor - pyflow
Is the latest version of pyflow (2.0.2) compatible with your work @microelly2? Or are there still patches needed?
Reason: fixed broken "mention"
- microelly2
- microelly2
I made a pyflow node using Euler method to simulate the SIR model.
The video is in German, it demonstrates the calculation of curves based on differential equations using parameters and data series generated from a sketcher curve.
I think this can be a way to implement other/more technical models based on differential equations too.
For me this has more priority than classical CAD because I want to know more about the future than the politicians' opinions and the news broadcasts.
- microelly2
curve fit node
- microelly2
Added two more nodes
Apply Function: calculates the fitting curve for a new set of x values
Plot2D: plots the function into 2D Space as Polygon instead into a matplotlib window. So the result can reused for further CAD steps.
- microelly2
The interface to csv data
How to load, filter and plot data from csv files
Hello @microelly2
first thanks for your awesome work. I watch lot of pyflow vidéo and I'm imprest. It look to offer so many possibility.
Sadly I encounter some issue during the installation.
I have try to install it with different way. So far the result I got was:
I also use conda with
I and follow your github instruction.
and check that the 3 git repo are clone on ~/.FreeCAD/Mod
and I test all the import and print
but when I open the the PyFlow Workbench
run the Script "create all Nodes for Test" from Menu tests
then the pyflow window close and I got In the report view this message.
Did you have any Idea of what's going wrong.
I have try few hours but I run out of Idea of what to try to get the installation complete.
note I got the same result with
and
If some one have any Idea of what can I do to solve it.
freecad-daily
OS: Linux Mint 19.3 (LXDE/Lubuntu)
Version: 0.19.
Python version: 3.6.9
Qt version: 5.9.5
conda create -n freecad2 freecad=0.19.pre
---------get FreeCADPyFlow------------------- getInstance @ .../home/ranska/.FreeCAD/Mod/NodeEditor/nodeeditor/pfwrap.py li: 46
<nodeeditor.freecad_pyflowapp.FreeCADPyFlow object at 0x7fb0eb65b508>
create instance getInstance @ .../home/ranska/.FreeCAD/Mod/NodeEditor/nodeeditor/pfwrap.py li: 72
Running the Python command 'Micro_createAllNodesforTests' failed:
File "<string>", line 199, in Activated
File "/home/ranska/.FreeCAD/Mod/NodeEditor/nodeeditor/Commands.py", line 1202, in createAllNodesforTests
from PyFlow.Packages.PyFlowFreeCAD.Nodes.FreeCAD_Coin import nodelist
No module named 'PyFlow.Packages.PyFlowFreeCAD'
freecad-daily
conda run freecad-daily
I would leave your node editor for cad stuff and suggest to have a look at https://www.knime.com/ for a more general data science/analytics
https://www.youtube.com/user/KNIMETV/videos
https://hub.knime.com/search?q=covid
- microelly2
Thank you for the link. I wrote the nodes after my investigation of the corona data sets, but the nodes are not only useful for this kind of data.saso wrote: ↑Sat Apr 11, 2020 12:13 am I would leave your node editor for cad stuff and suggest to have a look at https://www.knime.com/ for a more general data science/analytics
I see here a way to use external tables( in this first stage only simple csv files) as parameter sets for cad models.
For example: write the parameters for screws and bolts or lege briggs into csv files and select them by the methods I demonstrated. At the end there in no plot but a configrured 3d part.
The methods will work for other interfaces too: the database interface to neo4j/cypher
and in future: interfaces to sql, json and xml.
My idea is to have more and more packages outside freecad:
csv(working name www) , cypher,
- microelly2
You still have to register the package see:
https://forum.freecadweb.org/viewtopic. ... 40#p360762
One more remark:
I still have to publish the new packages cypher and www:
*add documentation
* refine code
*tests and make the nodes robust.
this will happen next days.
