node editor - pyflow
microelly2
Re: node editor - pyflow
Postby microelly2 » Thu May 23, 2019 6:23 am
tak wrote:
Thu May 23, 2019 2:12 am
It is working now. But I don't know why there is nothing is propertyView
In my version the property tab is already inside FreeCAD window.
If you start my test_AA examle (left button) you get the node view and the property view as dockwidgets inside FreeCAD.
If you select a node the property tab is filled with the data of the selected node.
tak
Postby tak » Thu May 23, 2019 7:05 am
where is the test_AA example?
microelly2
Postby microelly2 » Thu May 23, 2019 8:08 am
I will make a short video at home to demonstrate the current workflow.
microelly2
Postby microelly2 » Thu May 23, 2019 8:11 am
Does it make sense to implement the grasshopper nodes?
http://rhino.github.io/index.html
making the node editor like grasshopper we can test against the grasshopper use cases.
tak
Postby tak » Thu May 23, 2019 8:23 am
when I click tools>property in pyflow
there is an error message.
bitacovir
Postby bitacovir » Thu May 23, 2019 6:54 pm
This could bring more attention and feedback from Grasshopper users.
::bitacovir::
My Blog
Mini Airflow Tunnel Project
looo
Postby looo » Thu May 23, 2019 7:21 pm
What we really need is a solid implementation of the node-editor itself. This means a concept to go from python objects to nodes in a easy way. What we also need is a modular system where everyone can add nodes easily and provide them via a package-manager or the addon-manager. We should think about a way to support FreeCAD-features, but I think a replacement of the dependency-graph itself is not feasible.
looo
Postby looo » Thu May 23, 2019 8:16 pm
@microelly2 this is not working for me :D
Missing parentheses in call to 'print'. Did you mean print(m)? (fc_flow.py, line 199)
looo
Postby looo » Thu May 23, 2019 9:08 pm
@microelly2 any chance you are moving over to python3? There are a lot of stuff not yet compatible with python3 in your modified library... I guess a node-editor not compatible with python3 has not much future.
microelly2
Postby microelly2 » Fri May 24, 2019 8:40 am
There are not to many free node-editors available which can be embedded into FreeCAD.
I used some years ago pse (Python simulation editor) but pse is meantime ported from Qt to kivy, and there is no way to bring kivy and FreeCAD together.
https://youtu.be/X659BgaxutQ
PyFlow is already very complex - 30.000 lines of code.
It takes some time to read te source to understand how it works in detail and where FreeCAD can connect.
So my priorities are:
1. Is it possible to implement a use case where the node-editor simplifies the CAD workflow
2. Is it possible to add specific node types for FreeCAD concepts as separate python libraries
3. make Pyflow python3 compatible: PyFlow uses Qt.py and Qt.py is compatible to python 2 and 3 https://pypi.org/project/Qt.py/
