Curved Shapes Workbench
GlouGlou
Re: Curved Shapes Workbench
Postby GlouGlou » Wed Nov 06, 2019 9:47 pm
And finally made wing and his winglet. ;)
SoaringWing.FCStd
(177.1 KiB) Downloaded 35 times
christi
Postby christi » Sat Nov 30, 2019 8:37 pm
I have added a new tool: Notch Connector
It cuts notches into the overlapping part of two bars
cranec
Postby cranec » Sun Feb 23, 2020 11:25 am
I Have a problem when loading this WB; during the init, i have this message
Log: Init: Initializing C:\Users\ome\AppData\Roaming\FreeCAD\Mod\CurvedShapes... failed
Log: ----------------------------------------------------------------------------------------------------
Log: Traceback (most recent call last):
File "<string>", line 120, in InitApplications
File "<string>", line 51, in <module>
File "<string>", line 11, in __init__
File "C:\Users\ome\AppData\Roaming\FreeCAD\Mod\CurvedShapes\CurvedShapes.py", line 5, in <module>
from importlib import reload
ImportError: cannot import name reload
christi
Postby christi » Sat Feb 29, 2020 9:34 am
You can comment out the line
#from importlib import reload
then search for all
reload(whatever)
commands and comment out them as well.
Restart FreeCAD to apply the changes.
These instructions are only neccessary if you are working at the source code. They will always reload the python files when you create a new CurvedArray. Not sure why this does not work on your system. Are you using python version 3 ?
Postby Kunda1 » Sat Feb 29, 2020 2:30 pm
This is very cool! But honestly a little perplexing why it's in a 'Curved Shapes' workbench. I bet the carpenters, woodworkers and the Arch folks would love this feature. Though I doubt they'd think to look in this workbench for this feature.
christi
Postby christi » Fri Mar 06, 2020 1:53 pm
I have added a distribution algorithm to CurvedArray and CurvedSegment.
Default Distribution: linear
Distribution: parabolic (x²)
Distribution: x³
Distribution: sinusoidal
Distribution: elliptic
Postby Kunda1 » Fri Mar 06, 2020 2:03 pm
Nice! Can you elaborate on what the usecase for each one would be?
christi
Postby christi » Fri Mar 06, 2020 2:26 pm
If you create a surface with the Curved Array, a different distribution may give you better results.
If you create an elliptic wing, distribution elliptic would be the best solution.
If you create the Curved Array inside a half circle, sinusoidal is best.
If the hullcurves are created from simple spline curves, parabolic or x³ may give you the best results.
If you are unsure, choose linear.
Postby Kunda1 » Thu Mar 26, 2020 3:20 pm
JOKO Engineering made a tutorial on using CurvedShapes
phpBB [video]
khumarahn
Postby khumarahn » Mon Mar 30, 2020 12:10 pm
A very impressive workbench!!! And may thanks to Joko for his video.
I am trying to design a fan duct for a 3d printer, and hitting an issue trying to connect to rectangle sketches which are at 90 degrees to each other with a Curved Segment, at the end of the profile.
It can get a bit better with less interpolating items, but there is always a (small in size) warping at the end.
Can this be helped?
test.FCStd
(42.62 KiB) Downloaded 5 times
