Curved Shapes Workbench
Re: Curved Shapes Workbench
The vertexes are not aligned, you should redraw the sketches or use joincurve. Joincurve have a offset option now is need.
Corner break parameter can be used as well.
- CurvedSegment.FCStd
- (19.96 KiB) Downloaded 62 times
- Capture.JPG (24.9 KiB) Viewed 2850 times
- Capture2.JPG (57.24 KiB) Viewed 2850 times
Hi Zolko and GlouGlou,
As you found out, the Twist parameter did not work with sketches that have more than one line segment.
Creating a join curve solves this by 1. creating a single curve and 2. moving the starting point to the top.
For those who do not know this trick and to get rid of the problem with the twist parameter, I have implemented Zolkos approach to reorder the line segments. The twist parameters will now reorder the line segments instead of the pole points of the lines. If you have 6 line segments, you can apply twists with a multiple of 60 degrees. I think this will work for most designs.
Check out the new version of the CurvedShapes Workbench.
InterpolatedMiddle doesn't work with this file. Or I missed something?
- interpolated.FCStd
- (15.21 KiB) Downloaded 60 times
cuvres WB shrunk my work?
so it look sliek it shurnk one side and grew the otherside in length how do i fix this?
- Handle.FCStd
- (157.91 KiB) Downloaded 54 times
- bottom.png (94.59 KiB) Viewed 2682 times
Reason: Mod note: thread merged in to the main Curves Workbench thread
Re: Curves workbench
krazywulf1983 wrote: ↑Fri Nov 20, 2020 2:08 am so it look sliek it shurnk one side and grew the otherside in length how do i fix this?
Mod note:
@krazywulf1983 your thread was merged in to the main Curves Curved Shapes WB thread. Please always paste your full About info in to posts you're asking assistance with. Please edit the above post to do just that. Thank you
Reason: Curved Shapes not Curves workbench
This user uses Curved Shapes WB, not Curves.Kunda1 wrote: ↑Fri Nov 20, 2020 5:25 amkrazywulf1983 wrote: ↑Fri Nov 20, 2020 2:08 am so it look sliek it shurnk one side and grew the otherside in length how do i fix this?
Mod note:
@krazywulf1983 your thread was merged in to the main Curves WB thread. Please always paste your full About info in to posts you're asking assistance with. Please edit the above post to do just that. Thank you
:facepalm:
Ok, fixed. Apologies.
Re: cuvres WB shrunk my work?
Select the Sketch BottomFront and select BoundingBox in the View menu. Your base item BottomFront is bigger than the sides Sketch004 in y direction. This is why it is shrunk. To fix this, make a copy of Sketch004 and move the bars so they will cross the boundung box of BottomFront.krazywulf1983 wrote: ↑Fri Nov 20, 2020 2:08 am so it look sliek it shurnk one side and grew the otherside in length how do i fix this?
How does one get the "Items" (shown in orange) to follow the hull curve rather than be parallel to the "Base"?
And what controls the last couple items? Is it possible to have them scale (not sure scale is the right word...) so they fit between the hull curves?
OS: Ubuntu 20.04.1 LTS (XFCE/ubuntustudio)
Version: 0.19.
Branch: unknown
Hash: b082c813f820ebdb837ba6ace4b9124f9a73cc4a
Python version: 3.8.5
Qt version: 5.12.8
Version: 0.19.
Branch: unknown
Qt version: 5.12.8
