I think this will make my tool too complicated
Curved Shapes Workbench
- miniellipse
Re: Curved Shapes Workbench python errors
I updated fcad on my mac and when I load an example file from the forum, I get this errors in report view:
10:18:40 Traceback (most recent call last):
File "/Users/ADMacMini/Library/Preferences/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 196, in onChanged
self.execute(fp)
File "/Users/ADMacMini/Library/Preferences/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 179, in execute
self.makeRibs(prop)
File "/Users/ADMacMini/Library/Preferences/FreeCAD/Mod/CurvedShapes/CurvedArray.py", line 93, in makeRibs
d = CurvedShapes.distribute(x / (sections - 1), obj.Distribution, obj.DistributionReverse)
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Distribution'
self.execute(fp)
self.makeRibs(prop)
self.execute(fp)
self.makeRibs(prop)
Any help is appreciated.
OS: macOS 10.16
Version: 0.19.24366 (Git)
Python version: 3.9.7
Qt version: 5.12.9
OCC version: 7.5.3
Locale: C/Default (C)
self.execute(fp)
self.makeRibs(prop)
self.execute(fp)
self.makeRibs(prop)
self.execute(fp)
self.makeRibs(prop)
OS: macOS 10.16
Qt version: 5.12.9
OCC version: 7.5.3
- Sirius_2009-Wing.FCStd
- (362.66 KiB) Downloaded 62 times
Could be like this or something looks like.
- Sirius_2009-Wing_vb.FCStd
- (262.41 KiB) Downloaded 66 times
- miniellipse
Ha ha.. I thought by now, you would have finished this plane. I am trying to learn somethings but I upgraded my home computer to OSX Monterey and now I have issues with the Curves WB. I got these same errors when I opened your new Sirius_2009-Wing_vb file. I really think the system upgrade broke/changed some python things but I do not know how to fix.
Thank you so much christi for the Notch Tool.
I have difficulties using it.
When I do the Notch the parts turn 90 degres............
- Notch test Link before.FCStd
- (4.78 KiB) Downloaded 57 times
- Notch test Link after.FCStd
- (10.11 KiB) Downloaded 54 times
- Before Notch.png (7.78 KiB) Viewed 3050 times
- After Notch.png (8.55 KiB) Viewed 3050 times
Concevoir en bois avec FreeCAD: https://www.lairdubois.fr/pas-a-pas/114 ... -bois.html
Your design was created with an older version of the CurvedShapes workbench. Delete and re-create the Curved Array parts to get them updated.miniellipse wrote: ↑Sat Mar 26, 2022 5:37 pm I updated fcad on my mac and when I load an example file from the forum, I get this errors in report view:
It seems that the algorithm to find out the cut direction does not work. Since I have not found a solution for this, you can manually change the parameter Cut Direction in your design. Set Cut Direction to 0,0,1 for the first NotchConnector and 0,0,-1 for the second. Enter the z value first, because 0,0,0 will again evaluate to the wrong values.
Hello Guys,christi wrote: ↑Sun Apr 10, 2022 6:35 amYour design was created with an older version of the CurvedShapes workbench. Delete and re-create the Curved Array parts to get them updated.miniellipse wrote: ↑Sat Mar 26, 2022 5:37 pm I updated fcad on my mac and when I load an example file from the forum, I get this errors in report view:
I am experiencing the same like miniellipse, but with a freshly updated system and .AppImage:
OS: openSUSE Leap 15.3 (GNOME/default)
Version: 0.20.28647 (Git) AppImage
Branch: (HEAD detached at 1c1743b)
Hash: 1c1743b67d209f2b6501de4f75645a33b69d1c31
Python 3.9.12, Qt 5.12.9, Coin 4.0.0, OCC 7.5.3
Locale: Hungarian/Hungary (hu_HU)
Installed mods:
* Plot
* Curves 0.4.2
* MeshRemodel 1.8919.0
* fasteners 0.3.40
* CurvedShapes 1.0.2
* Silk -1861983584.0.0
* sheetmetal 0.2.49
* AirPlaneDesign 0.4.0
* Assembly4 0.11.10
* Manipulator 1.4.3
14:55:44 Traceback (most recent call last):
File "/home/zivatarw/.local/share/FreeCAD/Mod/CurvedShapes/./CurvedArray.py", line 196, in onChanged
self.execute(fp)
File "/home/zivatarw/.local/share/FreeCAD/Mod/CurvedShapes/./CurvedArray.py", line 179, in execute
self.makeRibs(prop)
File "/home/zivatarw/.local/share/FreeCAD/Mod/CurvedShapes/./CurvedArray.py", line 114, in makeRibs
if (obj.Surface or obj.Solid) and obj.Items > 1:
<class 'AttributeError'>: 'FeaturePython' object has no attribute 'Surface'
14:55:44 16Standard_Failure Need at least two vertices, edges or wires to create loft face
14:55:44 Creation of surface is not possible !
14:55:44 <Part> ViewProviderExt.cpp(1268): Cannot compute Inventor representation for the shape of Test2#CurvedArray: Bnd_Box is void
Thanks,
Zivatar
Meanwhile I carried out a different test:
Symptoms are the same on a different fresh system.
KR,
Zivatar
KR,
Zivatar
