jmaustpc wrote: ↑Sat Jul 06, 2019 4:28 am
I just tried opening your engine stp file here in FreeCAD daily on my old dual core laptop. Both cpu cores seem to be being used and are at times both simultaneously at 100%. That is one big slow to open file!
Have you tested the multicores trigger with htop or similar tools?
ATM I haven't found anyone having multicores triggered on linux during file loading...
I ran FreeCAD daily loading your large step file, and looked a htop, once again both cpus jumped up and down in usage amount, but sometimes both were up at the same time.
OS: Ubuntu 18.04.2 LTS (KDE/plasma)
Version: 0.19.
Python version: 3.6.8
Qt version: 5.9.5
jmaustpc wrote: ↑Mon Jul 08, 2019 10:57 am
Version: 0.19.
Qt version: 5.9.5
Hi @jmaustpc
thanks for your detailed feedback.
From your htop screenshot only CPU1 is triggered to 94.1%...
what we noticed is that the process jumps randomly from a CPU to an other, but always triggering a single CPU at time.. and from your screenshot it seems it is exactly the same on your pc.
On Win and OSX instead, all CPUs get triggered simultaneously at about 25-45%
easyw-fc wrote: ↑Sun Jul 07, 2019 1:51 pm
Ok, I'm going to ask some tips to @realthunder, who helped in developing the FC Appimage and improved OpenGL for his A3 branch...
You can use the ProcessExplorer to get a better view of CPU usage per thread. Open the process explorer, find the process, right click and choose 'Properties', and finally select the 'Threads' tab.
There are two distinct phases of STEP import in FC, the first phase (which shows the progress bar) happens entirely in OCCT. It reads the file and build all the shapes. The second phase is for FC to fetch those shapes and create objects and constructing 3D representations. What I found out is that OCCT runs only single threaded in the first phase. It does use multithreading in the second phase, for meshing I believe. I did a quick search around OCCT source code. There are actually only very few places that can run in parallel, one is in BOP tools, and the other is for meshing, and maybe some others I've missed.
Try Assembly3 with my custom build of FreeCAD at here.
realthunder wrote: ↑Wed Jul 10, 2019 7:50 am
ProcessExplorer is a Windows program,
Do you know how to do something similar in Kubuntu 18.04?
Hi @realthunder,
thanks for coming in....
What I'm spotting here is that FC is loading the example STEP file using multicores both on Win and OSX, but instead uses only one core at time on Linux (jumping through the cores randomly).
This is quite strange and also disappointing because on Linux I acknowledge a worst performance, a less responsive pc during the loading and a higher CPU temperature.
Could you please to have a look using the STEP model and testing your A3 Appimage?
I made a simple comparison on my Linux PC and I noticed a similar behavior between your A3 and the main branch build.
Both behave similar under linux, without triggering the multicores, as instead it happens on win and osx.
Thx again
Maurice.
easyw-fc wrote: ↑Wed Jul 10, 2019 6:28 pm
I tested on both mine and upstream images. They behave about the same. And yes on Linux it behave just like you described. But I observed the same on my Windows laptop, which is a quite old machine, so its even slower. Can you please download the process explorer in my previous post and test it on your Windows machine?
PS to test the multicore / multithread, it is enough to open the linked STEP file (I just used a script to calculate also the loading time).
The STEP file is downloadable at this dropbox link (it is possible to download it without the need to register, clicking on 'No thanks, continue to view').
Hello, Maurice,
of course I'm happy to help - and as best I can.
But I am still on holiday in beautiful Bulgaria until next week Wednesday included.
Here I have only an older weak notebook with me, without a CAD-Exchanger license.
