If names are used to denote the dimensionals constraints then some very intelligent algorithm replaces the numbered references to names. This works often but not always.
To make CarbonCopy more robust I would like to see the following workflow:
- Create the source sketch, give names to dimensional constraints
- Create a CarbonCopy. If it exists CarbonCopy uses the name, else it uses the number as before.
This would make the model more robust against changes and on top it would be easier to understand the carbon copy if names are used in a sensible way.
What do you think?
Abdullah wrote:ping
