App::Link: the big merge
Site Admin
Re: App::Link: the big merge
Postby wmayer » Mon Sep 02, 2019 11:24 am
In the German forum another critical bug has been reported: https://forum.freecadweb.org/viewtopic.php?f=13&t=39023
The steps to reproduce:
  • Switch to Part wb and create a document
  • Create a Part container and a box
  • Move the box inside the Part container
  • Start fillet or chamfer tool
  • In the 3d view select an edge of the box
FreeCAD freezes and starts to allocate more and more memory. The memory allocation happens because the selection's internal list "_SelList" grows and grows and starting from the 2nd element all entries are identical. For the first element only the x,y,z coordinates are different.
Looking at the call stack this is what happens:
DlgFilletEdges::onSelectionChanged reacts on the selection change and calls DlgFilletEdges::toggleCheckState. This calls Gui::Selection().addSelection() where object name is Box and sub-name e.g. Edge3.
Internally SelectionSingleton::checkSelection() fills up the passed reference of _SelObj and sets FeatName to "Part" and SubName to "Box.Edge3" and then it tries to find this entry in _SelList but cannot find it there because the passed pObjectName is still set to "Box".
realthunder
Postby realthunder » Mon Sep 02, 2019 1:21 pm
Zolko wrote:
Mon Sep 02, 2019 11:11 am
When I insert a link (App::Link), it has a Placement and a Link Placement property, which seem identical: when I modify one, the other is changed. What is the rationale behind it ? Testing with the lates AppImage 18009 on Linux:
They are internally synchronized. When 'LinkTransform' is set to true. The Link will hide its Placement property from the property editor. Instead, the editor will display the linked object's Placement in green font. In fact, any property showing green belongs to the linked object.
When 'LinkTransform' is false, the link display the 3D view object independent of its original placement. When it is true, it is synced to the linked object's placement. You can set additional placement (now accessible as the LinkPlacement property) as an offset. See the video demo below
link-transform.webm
realthunder
Postby realthunder » Mon Sep 02, 2019 1:26 pm
PR submitted here
Zolko
Postby Zolko » Mon Sep 02, 2019 4:49 pm
I'm sorry, I don't understand. And I think you forgot to attach the demo video. You mean that if LinkTransform==False, then there are 2 successive Placements applied to it: Placement and LinkPlacement ? What is the use-case ?
realthunder
Postby realthunder » Mon Sep 02, 2019 10:30 pm
Two sucessive placements, yes, but it is the Link's LinkPlacement (which can be considered as an alias to Link's Placement), and the linked object's Placement. Being able to track linked object's placement is very important in many use case, like the asm3 constraining element is a link that follows its target.
link-transform.webm
(407.21 KiB) Downloaded 37 times
Zolko
Postby Zolko » Tue Sep 03, 2019 6:26 am
OK. I always think about App::Link as links between documents, not links inside the same document.
May I suggest that the boolean's name LinkTransform is not very self-explanatory ?
realthunder
Postby realthunder » Tue Sep 03, 2019 6:59 am
Yes, it is not the best choice. But changing the property name is not worth it IMO. Maybe some more explanatory tooltips. Normal user shouldn't need to change this property anyway. There are two Link creation buttons exposed now. The second button is meant to create a placement tracking link.
App::Link: the big merge: Reverting crashes FreeCAD
Postby chrisb » Tue Sep 03, 2019 7:10 am
Reverting of some models still crashes FreeCAD. Other models are ok.
- download the model attached to this post: https://forum.freecadweb.org/viewtopic. ... 34#p331325
- start FreeCAD
- open 0902-thick_cb.FCStd
- File->Revert
->Crash
OS: macOS High Sierra (10.13)
Version: 0.19.18009 (Git)
Hash: 0641ca0d1e020d18f23d2adb49959195266f04f7
Python version: 3.7.3
Qt version: 5.12.1
Locale: English/Germany (en_DE)
vocx
Postby vocx » Tue Sep 03, 2019 11:39 pm
I created the Std LinkMake page in the wiki to start collecting information on how to use these tools.
The second button calls Std LinkMakeRelative but is still empty. If you already have user documentation on how to use these new tools, then we can start filling the pages in the wiki, and creating examples that everybody can reference.
There were also many icons added, I guess for further buttons or menu commands. They were added to the src/Gui/Icons section in Artwork.
realthunder
Postby realthunder » Wed Sep 04, 2019 12:59 am
I have a recent adjustment of this button function. I'll put more details when I submit the PR.
I'll add details for that too.
