Hello!
ickby wrote: ↑Mon Aug 19, 2019 6:12 am
One more thing: I always envisioned the toolbar, which holds the groups, also holding a link button like so:
+1
I found another tree issues with link merge. (Should i open a new topic about the issues about the merge in gerneral?)
1. When i make an assembly with links and i do change anything in the assembly - any kind of property - FreeCAD recomputes and retouch all single elements of it. In my assembly, this take around two minutes of every step i take. Is this intention?
2. When i reopen an assembly that have a array link (DraftWB) in it, the reopen of the array fails.
- _dead_array.png (346.31 KiB) Viewed 1973 times
File "/home/pc/Programs/FreeCAD/Mod/Draft/Draft.py", line 5734, in onDocumentRestored
self.linkSetup(obj)
File "/home/pc/Programs/FreeCAD/Mod/Draft/Draft.py", line 5831, in linkSetup
_DraftLink.linkSetup(self,obj)
File "/home/pc/Programs/FreeCAD/Mod/Draft/Draft.py", line 5713, in linkSetup
obj.configLinkProperty('ShowElement')
<class 'ValueError'>: cannot find property 'ShowElement'
15.7329 <App> Document.cpp(2470): Failed to restore _100_Assembly#Array: cannot find property 'ShowElement'
3. When i recompute the array link (see above), the error still exist, but the sign of the error is away. And when i click on the link of tha array, than i get an selection error. I also get the selection error in TechDrawWB, but is pretty hard to reproduce. I will it post when i find a minimal way to reproduce.
- _selection_error.png (306.76 KiB) Viewed 1973 times
309.853 Selection.cpp(1558): Sub-object _100_Assembly#Array.Link017. not found
I just want to say that the workflow itself is pretty neat.
Greetings
user
