Crossbeam exercise
GlouGlou
Re: Crossbeam exercise
Postby GlouGlou » Thu Jul 18, 2019 9:13 pm
First step something looks like. not so easy without fillet feature for surface.
and offset doesn't want work. :roll:
crossbeam.FCStd
(528.97 KiB) Downloaded 8 times
saso
Postby saso » Thu Jul 18, 2019 10:42 pm
Thanks for the main curves and your model :) I quickly played a bit with it and got a bit further... but not the best workflow :?
microelly2
Postby microelly2 » Fri Jul 19, 2019 8:20 pm
Here is the pyflow graph for the first surface.
The idea was starting with 9 points create some helper poles and then build the poles matrix for the bspline surface.
bb.FCStd
(29.8 KiB) Downloaded 12 times
microelly2
Postby microelly2 » Sat Jul 20, 2019 3:36 pm
here my solution for the 2nd task:pad something onto a nonplanar surface.
I have problems with fillet and chamfer on bspline surfaces, so for rounded edges its need some more tricks and a little bit of time.
I made two new nodes
FreeCAD UV projection uses methods from the nurbs workbench - draw on face it uses the parameter method of a Bspline Surface.
FreeCAD Parallel projection uses the makeParallelProjection method of a Face
Other projection methods may come later.
phpBB [video]
Postby Kunda1 » Sat Jul 20, 2019 4:00 pm
This is next level stuff! Nice!
GlouGlou
Postby GlouGlou » Sat Jul 20, 2019 4:20 pm
which tool you use to make the surface?
microelly2
Postby microelly2 » Sat Jul 20, 2019 5:14 pm
you can inspect the code
the whole workflow is scripted in crossbeamexample()
https://github.com/microelly2/NodeEdito ... L830-L1110
https://github.com/microelly2/NodeEdito ... #L840-L866
and the real code is still swapped to
https://github.com/microelly2/NodeEdito ... #L144-L180
lines will change with next commit :roll:
microelly2
Postby microelly2 » Sat Jul 20, 2019 5:28 pm
I watched sverchok for years, but it was not possible to port it to freecad in freetime:
With Pyflow we have the ability get comparable design power.
praise ilgar and pedro who gave us this wounderful framework.
GlouGlou
Postby GlouGlou » Wed Jul 24, 2019 7:45 pm
after spent few hours, step2. :D
