using the last AppImag i got several error messages if i open a file wich is mostly created/reworkd with the Appimage 0,19.17512, which is just one AppImage release before...
File "/tmp/.mount_FreeCAHdgDq0/usr/Mod/Draft/Draft.py", line 3684, in attach
self.onChanged(vobj,"Pattern")
File "/tmp/.mount_FreeCAHdgDq0/usr/Mod/Draft/Draft.py", line 3710, in onChanged
if str(vobj.Pattern) in list(svgpatterns().keys()):
File "/tmp/.mount_FreeCAHdgDq0/usr/Mod/Draft/Draft.py", line 611, in svgpatterns
loadSvgPatterns()
File "/tmp/.mount_FreeCAHdgDq0/usr/Mod/Draft/Draft.py", line 581, in loadSvgPatterns
import importSVG
<class 'SyntaxError'>: invalid syntax (importSVG.py, line 746)
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
loadSvgPatterns()
import importSVG
I noticed that the download size has grown by about 40mb, which suggests to me that some bigger changes are includet.
I don't notice a prob at the file and the work with it (until now), so the question is just to get sure...: Should i hold the 0.19.17512 Appimage to be able to work with files before 0.19.17646 ?
