Feature request: Default way for naming derived dimensions.
jruiz
Postby jruiz » Tue Aug 27, 2019 1:25 pm
  • Consider a fully constrained sketch.
  • Suppose, for example, the distance D between two points arising in the sketch.
Wouldn't it be nice to name D for using/referencing it later in the project? That is without adding superfluous constrains.
For example in the attached image the needed parameter would be the length of "line (Edge3)"
DeepSOIC
Re: Feature request: Name derived dimensions.
Postby DeepSOIC » Tue Aug 27, 2019 1:53 pm
Postby chrisb » Tue Aug 27, 2019 4:28 pm
Just in case: don't give that name to the (blue) reference constraint if you want to use it in an expression. Use only characters, underscores and numbers; start with a character. Especially: no blanks, no brackets, no point, no colon, no -,+,*,/.
jruiz
Postby jruiz » Tue Aug 27, 2019 5:30 pm
Excellent!
Thanks a lot.
BTW, it would be very useful to have the option of naming the "blue constrain" when "creating" it.
Postby Kunda1 » Tue Aug 27, 2019 5:31 pm
Should it be marked [Solved] then?
jruiz
Postby jruiz » Tue Aug 27, 2019 5:37 pm
What do you think about adding the option of naming the "blue constrain" when creating it?
DeepSOIC
Postby DeepSOIC » Tue Aug 27, 2019 5:39 pm
Only if not in the current blocking pop-up style. If on a task panel, +1.
kisolre
Re: [Solved]Feature request: Name derived dimensions.
Postby kisolre » Tue Aug 27, 2019 6:21 pm
Reference constraints are not always created to be used elsewere. So them having names is not always needed and will be a nuisance if always required. For example I frequently change real to reference dimensions to check possible range of change or other constraint scheme. I dont need names for those.
RatonLaveur
Postby RatonLaveur » Tue Aug 27, 2019 6:39 pm
I already chipped in this week about this, but since the conversation seems to continue here here's my take on it:
Switching from normal to construction geometry changes nothing of the FreeCAD behaviour except it's now blue. Blue lines are editable normally.
Switching from normal to reference constraint at the moment not only intereferes with auto update with the bogus redundancy conflict (being solved already) but also prevents you from optional naming (if trying to name it,the constraint goes back to real constraint) and from editing (switches to real constraint).
In my opinion this is both counter intuitive and lead me to significant frustration. The obvious bias towards real constraints is offensive and us, reference constraint lovers feel slighted! :)
Currently naming a reference constraint does work by editing it manually in the constraints list, which means functionality is not impaired. But intuitiveness and user friendliness (as well as logic in my opinion) are suffering.
DeepSOIC
Postby DeepSOIC » Tue Aug 27, 2019 8:15 pm
I totally agree, it should be improved. The constraint becoming red after OKing the pop-up is totally unintuitive (but useful in some situations).
cron
