Feature Request: PartDesign Pocket, add intersect option in addition to subtract
townkat
Re: Feature Request: PartDesign Pocket, add intersect option in addition to subtract
Postby townkat » Sat Sep 14, 2019 9:56 pm
chrisb wrote:
Sat Sep 14, 2019 1:22 am
doesn't work anymore if you have already nested geometry:
I tried your example and it showed the multiple solids error. I think nested geometry in pocket always results in multiple solids. It must first work as pocket to be able to use the rectangle trick I think.
openBrain wrote:
Sat Sep 14, 2019 8:13 am
Just want to remember that for robustness purpose, you can bind the dimensions of the outer rectangle with latest Pad shape,
Pad063.Shape.BoundBox.XLength
another useful info, thank you :)
Postby chrisb » Sun Sep 15, 2019 2:12 am
That's not the cause. If you limit the depth so that it does not go through all, then the pocket works while it doesn't with an additional outer rectangle.
Bildschirmfoto 2019-09-15 um 10.12.49.png (19.07 KiB) Viewed 237 times
kisolre
Postby kisolre » Sun Sep 15, 2019 5:44 am
If I understood correctly it was more of an example where inverse pocket/common could be used. Leave everything betwhhen the circles and remove everytning else. and in that case just adding extra big rectangle will not work because this gives 3 contours and what is inside and what outside is not determined properly.
townkat
Postby townkat » Mon Sep 16, 2019 1:54 am
Thnx, i could reproduce it now, so it seems like a bug in pocket function. This will probably be fixed sometime, but i will still want our PartDesign common function :).
Postby chrisb » Mon Sep 16, 2019 4:03 am
PartDesign common is a sensible extension as ickby pointed out in the topic linked above. Check the tracker if a corresponding feature request exists, and if not you may create one and crossreference it to this and the old topic.
The restriction to one single solid only seems like bug, but isn't. That's how a PartDesign body is specified.
freecad-heini-1
Postby freecad-heini-1 » Mon Sep 16, 2019 5:44 am
Realthunder has eliminated the one solid rule in his branch. Hopefully we'll see that soon in Master, as well as the topo-naming improvements.
townkat
Postby townkat » Mon Sep 16, 2019 11:41 pm
Even with 3 nested shapes (like our example, rectangle included) it still remains a single solid, even more if pocket is not 100% depth, that's why I said it is a bug. It should start from outside and count object, empty, object, empty and so on trough the nested shapes to the center, but it only works up to 2 levels. Maybe not a bug, but a limitation of pocket tool, and maybe it will be improved in the future.
Postby chrisb » Tue Sep 17, 2019 1:42 am
It is indeed a (known) limitation, not a bug.
townkat
Postby townkat » Tue Sep 17, 2019 11:52 pm
"Add PartDesign Common operations" feature request created.
https://www.freecadweb.org/tracker/view.php?id=4135
