GSOC 2020 has been Green Lit! (GSOC is over, thanks to everyone involved!)
Re: GSOC 2020 has been Green Lit! (Voice your opinion and ideas about what to propose for the next gsoc)
@GSoC applicants
I suggest all GSoC applicants submit their draft proposal so that the community can review it. The last date of submission GSoC proposal is 31st March.
Thanks,
Thanks,
Hello Markus and welcome to the forum!kryptokommunist wrote: ↑Fri Mar 27, 2020 8:05 pm I'm Marcus, 24 and currently studying Computer Science masters at TU Berlin. I started using FreeCAD about 2 months ago for a light installation project of mine. When I saw that FreeCAD is participating in GSoC I thought this is a good match. I was a bit unsure because the schedule collided with my semester, but due to Corona I think my semester won’t likely happen anyways. So here I am.
What I considered:
I am strong in Python and my C++ experience consists mostly of Arduino projects. I've dabbled with Javascript, but never in a complex project.
- enabling easy publishing of a parameterised Model to the Web (Select parameters that should be tweakable in FreeCAD and then create a render library for the web that exposes those tweakable parameters)
I could implement one of these ideas as a stepping stone for the idea above first:
- default spreadsheet with all the parameters added in the GUI
- also the iPython Notebook integration would be related to this idea as well, as far as I understood it the idea was to render the model with Javascript/WebGL. From what I read on the forum I am unsure if this issue is still open? At least in the bug tracker it is.
- And my kinda moonshot idea: creating a tool for light design, so you could add light elements into your model and preview light sources, shades, animations
So any feedback from you in terms of what is realistic and fits with FreeCADs goals? I am also open for other suggestions. My favourite would be a combination of 1, 1a and 1b.
Maybe we can ping ickby to make him aware of your proposal:
This is a good idea. I have submitted issue #30: Measurement tool for FreeCAD
Also, while we're at it, what is the procedure for the follow-up ? I see that Yorik's proposal are labelled, is it done automagically or do I need to do something about it ? And, finally, how are the proposals filtered at the end, how are candidates affected, where can we find informations about the practical constraints ...
Thanks
Hi @Zolko,Zolko wrote: ↑Sat Mar 28, 2020 9:22 pm This is a good idea. I have submitted issue #30: Measurement tool for FreeCAD
You need to submit a proposal on GSoC website under BRL-CAD organisation with FreeCAD tag.
Student eligibility criteria: https://summerofcode.withgoogle.com/get-started/
You can also take examples from past GSoC proposals: https://forum.freecadweb.org/viewtopic. ... 29#p172591
How GSoC works?
https://summerofcode.withgoogle.com/how-it-works/
Thank-you. I fail to understand how to set a label/tag. So my proposal is still virgin: no FreeCAD tag, no Python, no difficulty ... How can I assign a FreeCAD tag ?amrit3701 wrote: ↑Sun Mar 29, 2020 8:30 am You need to submit a proposal on GSoC website under BRL-CAD organisation with FreeCAD tag.
I think normally, that is something one fo the admins can do. It maybe possible to self-assign a label though.
- Suraj Dadral
Hi @ZolkoZolko wrote: ↑Sun Mar 29, 2020 9:37 amThank-you. I fail to understand how to set a label/tag. So my proposal is still virgin: no FreeCAD tag, no Python, no difficulty ... How can I assign a FreeCAD tag ?amrit3701 wrote: ↑Sun Mar 29, 2020 8:30 am You need to submit a proposal on GSoC website under BRL-CAD organisation with FreeCAD tag.
You need to choose tag "freecad" while submitting draft proposal under proposal details. I attached screenshot for reference.
Thanks,
- ProposalSubmitUnderFreeCAD.png (136.53 KiB) Viewed 3793 times
Thank-you for your help, but I must be really stupid: in which page do you get those options ? What is the starting point ? I see many links to everything, but I don't find one that would say: click here to apply. Does such a link exist ?Suraj Dadral wrote: ↑Sun Mar 29, 2020 4:52 pm Hi @Zolko
- Suraj Dadral
Here is the link: https://summerofcode.withgoogle.com/org ... 230420480/Zolko wrote: ↑Sun Mar 29, 2020 5:13 pm Thank-you for your help, but I must be really stupid: in which page do you get those options ? What is the starting point ? I see many links to everything, but I don't find one that would say: click here to apply. Does such a link exist ?
Thanks,
