GSOC 2020 has been Green Lit! (GSOC is over, thanks to everyone involved!)
- kkremitzki
Re: GSOC 2020 (Voice your opinion and ideas about what to propose for the next gsoc)
Unfortunately writing code has to be the primary focus of a GSoC project, documentation can only be secondary.
Documentation is very important, of course. But if you accept this forum as part of the documentation - and it's really a highlight, that each user gets his individual documentation - then FreeCAD's documentation is just excellent.
It is rather a subject of "season of docs" : https://developers.google.com/season-of-docs/
Actually, there is a thread for that: https://forum.freecadweb.org/viewtopic.php?p=293510Opus wrote: ↑Sat Sep 28, 2019 9:37 amIt is rather a subject of "season of docs" : https://developers.google.com/season-of-docs/
Hi, I would like to have in Part-Design:
1.
The feature "Make draft on a face" can handle faces that are based on a spline.
2.
New features: Geometry-Mirror and Geometry-Pattern. If I insert these features at the end of a feature tree all the geometry before in the same body will be mirrored / patterned.
3.
Add hide and suppress feature to the context menu.
Thanks.
1.
2.
3.
Thanks.
+1. Instead of patterning individual features just pattern the whole final state.
- adrianinsaval
+1Hartwig wrote: ↑Sat Sep 28, 2019 5:02 pm Hi, I would like to have in Part-Design:
1.
2.
3.
Thanks.
Improve 3D offset. Or build a new feature.
3D offset is a key feature for surface design.
It crash too much and not be able to work with a combined surface.
- Upvote for a complete powerful user-friendly measuring tool
- Implement 2D offset tool in sketcher issue #3708 (don't know if @abdullah started something)
- Makes PartDesign Pad/Pocket options "Up to first", "Up to face" works with all type of faces, including curved ones (but maybe this an OCC thing)
- Implement Assimp importer & exporter for FreeCAD ? Bind to Assimp ?
- research the possibilities to use SE requirements with FreeCAD and do some basic implementation of it (for example importing the ReqIF - Requirements Interchange Format) https://www.omg.org/spec/ReqIF/, https://forum.freecadweb.org/viewtopic.php?f=8&t=38307
- research the possibilities to use MBSE/SysML with FreeCAD and do some basic implementation of it (for example with Papyrus) https://forum.freecadweb.org/viewtopic.php?f=8&t=38307
- research the possibilities to use Modelica with FreeCAD and do some basic implementation of it (for example with OpenModelica) https://forum.freecadweb.org/viewtopic.php?f=18&t=32556
- research the possibilities to use EnergyPlus with FreeCAD and do some basic implementation of it (for example with OpenStudio) https://github.com/NREL/EnergyPlus, https://github.com/NREL/OpenStudio
- research the possibilities to use LCA with FreeCAD and do some basic implementation of it (for example with openLCA) https://forum.freecadweb.org/viewtopic.php?f=8&t=52910
- research the possibilities to do diagrams in FreeCAD and do some basic implementation of it (for example with QElectroTech) https://qelectrotech.org/, https://en.wikipedia.org/wiki/Piping_an ... on_diagram
- research the possibilities to add "Subdivision Surfaces" in FreeCAD and do some basic implementation of it https://en.wikipedia.org/wiki/Subdivision_surface
- research the possibilities to use Julia with FreeCAD and do some basic implementation of it https://forum.freecadweb.org/viewtopic.php?f=8&t=42400
- research the possibilities to use HDF5 with FreeCAD and do some basic implementation of it https://forum.freecadweb.org/viewtopic.php?f=8&t=42070
- research the possibilities to use AI/ML with FreeCAD and do some basic implementation of it (for example with TensorFlow, PyTorch, FluxML, JAX,...)
