Can't convert from Wire to Bspline
herbk
Postby herbk » Thu Sep 19, 2019 8:42 pm
like the topic says, i can't convert a imported .dat file to a B-Spline. The object tree shows the BSpline Object, bot i got nothing at the main window.
OS: openSUSE Leap 15.1 (KDE//usr/share/xsessions/plasma5)
Version: 0.19.18227 (Git) AppImage
Hash: a374ecc8ef2abf38b146a1013a0f9700d1cb5fe9
Python version: 3.7.3
Qt version: 5.12.1
testprofile.FCStd
(17.73 KiB) Downloaded 15 times
Gruß Herbert
vocx
Re: Can't convert from Wire to Bspline
Postby vocx » Thu Sep 19, 2019 9:25 pm
Please indicate how you are importing the data. What type of data is this? A text file with a collection of vertices?
hammax
Postby hammax » Fri Sep 20, 2019 5:29 am
… if I have nothing else than the pure profile (-shape),
I'm trying to reproduce it by sketcher BSpline and to do it with a minimum of control points.
When the fitting is ok you can constrain it.
testprofile_2.FCStd
(22.23 KiB) Downloaded 10 times
herbk
Postby herbk » Fri Sep 20, 2019 6:19 am
Hi Hammax,
I know that. :D The post is not for asking for help, i want to show of that there something not works, what worked bevore...
BTW. If i need a profile i usualy recreate it with a sketcher B-Spline, because there is an other problem if conferting a profile from a .dat file to a B-Spline:
The end tip of the profile does not come off sharp. It shows some curios shape, depending at the profile a bit different.
Edit: Your pic dosn't show the BSpline at the object tree... Thats what i have:
And, like sayd, i just have it with the 0.19.18227 AppImage, not with Appimage 0.19.17681, the latest AppImage bevore "the big merge" i have.
Gruß Herbert
hammax
Postby hammax » Fri Sep 20, 2019 8:17 am
… OK in my FC0.19.17300 version Wire=>BSpline works (+recalculate)
Syres
Postby Syres » Fri Sep 20, 2019 6:52 pm
I believe the root cause is there were approx. 28 'Recompute' lines removed from Draft.py at least five months ago and this function obviously isn't used much as I'm not ware of it being reported since the change. So for the meantime, you need to press Ctrl+R (or click the Recompute icon) in order to clear the tick mark on the BSpline and it will appear on screen. If I can find the correct fix I'll submit a Pull Request as I can replicate on both:
OS: Windows 7 SP 1 (6.1)
Version: 0.19.18234 (Git)
Hash: 3af5d97e9b2a60823815f662aba25422c4bc45bb
Python version: 3.6.8
Qt version: 5.12.1
OS: Linux Mint 19.1 (X-Cinnamon/cinnamon)
Version: 0.19.18260 (Git) AppImage
Hash: dbf0644b60c35273525985fa13859ad39b0c10df
Qt version: 5.12.1
Syres
Postby Syres » Sat Sep 21, 2019 8:24 am
PR submitted https://github.com/FreeCAD/FreeCAD/pull/2542 to fix both directions Wire>BSpline and BSpine>Wire
herbk
Postby herbk » Sun Sep 22, 2019 7:20 am
Thank you very much.
Gruß Herbert
