Path workbench and OpenGL Vertex Buffer Object
Andrea3
Postby Andrea3 » Mon Sep 30, 2019 8:06 pm
Hello all,
I was still doing some trials with Path workbench, but I had some issues with the display of the parts.
When I create a Job, and I have opend the "Job edit" menu, is not possible to refresh the view.
If I try to move and/or rotate the part, everything disappears and I have to close and reload the file in order to see my model another time.
This problem is always present and I can easily repeat it.
I have supposed that this bug could be related to drivers or graphic issue, therefore I've opened "Preferences->Display" and I have seen the option "Use OpenGL Vertex Buffer Object".
With this option active, I don't have anymore any issue.
Somebody can explain to me why?
Thank you
PS: The behaviour described at the beginning should be reported as bug?
PPS: This is my configuration
OS: Windows 7
Version: 0.18.16131 (Git)
Branch: releases/FreeCAD-0-18
Hash: 3129ae4296e40ed20e7b3d460b86e6969acbe1c3
Python version: 3.6.6
Qt version: 5.6.2
Locale: Italian/Italy (it_IT)
kwahoo
Re: Path workbench and OpenGL Vertex Buffer Object
Postby kwahoo » Thu Oct 03, 2019 3:23 pm
Yes, but this can be a bug in the GPU driver too. You should try to reproduce this on a different PC (different GPU).
But, since VBO is the more modern (and faster) than default path, I think you shouldn't worry about it.
Andrea3
Re: Path workbench and OpenGL Vertex Buffer Object [CLOSED]
Postby Andrea3 » Fri Oct 04, 2019 12:05 pm
thank you for the answer.
I've tried on another PC and the issue is not present.
Probably a bug in my video driver.
I keep VBO option active.
