Let's talk about libredwg support
L_K
Re: Let's talk about libredwg support
Post by L_K »
tanks for all the work and effort you are putting in that project!
I'm relatively new to FreeCAD and just tried to install libredwg as described on the wiki page.
make is throwing this
~/libredwg/build$ make
make: *** No targets specified and no makefile found.  Stop.
digging into it I found "Determining if the include file pcre2.h exists failed" in an error log.
I didn't found a straight way how to resolve that. Dose anyone know what I'm missing?
I'm running linux mint
antonioferrinho
Post by antonioferrinho »
Hi all, thanks for all this effort. I am new to FreeCAD and to Linux (using for 1 year now). I recently updated my system to Linux Mint MATE 20.3.
I am trying to open a .DWG file (cannot share it due to property rights) and after going around the ODAFileConverter and 0.18 version of FreeCAD, I installed the daily version.
OS: Linux Mint 20.1 (MATE/mate)
Version: 0.19.
Branch: unknown
Hash: 070b5560d0cb244e9b142e7d76137ecfae3cf198
Python version: 3.8.5
Qt version: 5.12.8
So I tried to open the .dwg directly without changing anything on FreeCAD, and by default the ODAFileConverter (which is installed) couldn't do it, I was getting the error of the Qt_5.14 version not installed, as mentioned in this thread. I installed the 5.14.1 version of Qt, changed the version of Qt to be used, according to this thread and I receive the following info when using the
$ qmake -v
QMake version 3.1
Using Qt version 5.14.1 in /opt/Qt/5.14.1/gcc_64/lib
But the error from ODAFileConverter keeps displaying running it outside of FreeCAD:
/usr/bin/ODAFileConverter_21.11.0.0/ODAFileConverter: /lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.14' not found (required by /usr/bin/ODAFileConverter_21.11.0.0/ODAFileConverter)
So I quit this idea and went to libredwg. Downloaded and compile the tar.gz from libredwg webpage (version 12.1) following the instructions.
I removed the path to ODAFileConverter on the Preferences of FreeCAD, to leave just the option for libredwg, I believe.
When I open the .dwg, now it opens a window as if the document was imported and opened, but nothing shows on the board.
I get the following error on the report view:
18:54:55  Traceback (most recent call last):
  File "/usr/share/freecad-daily/Mod/Draft/importDWG.py", line 80, in open
    doc = importDXF.open(dxf)
  File "/usr/share/freecad-daily/Mod/Draft/importDXF.py", line 2795, in open
    Import.readDXF(filename)
<class 'RuntimeError'>: File doesn't exist
On the python console, I get the following:
>>> import importDWG
>>> importDWG.open(u"/media/antonioferrinho/8E28B77C28B761BF/01.Diversos/Spirala/Spirala Community Home files/SITE CAD & PDF PLAN/Spirala SITE CAD.dwg")
>>> # App.setActiveDocument("Spirala_SITE_CAD")
>>> # App.ActiveDocument=App.getDocument("Spirala_SITE_CAD")
>>> # Gui.ActiveDocument=Gui.getDocument("Spirala_SITE_CAD")
>>> ### End command Std_Open
Any thoughts that might help here?
P.S:writing this post I realised that FreeCAD recognizes Qt version different from the one that is configured. Both of them are installed.
antonioferrinho
L_K wrote: Wed Jan 27, 2021 4:58 pm Hi,
Did you try to use the make command inside the directory created by the extraction? Following these instructions? It worked perfectly for me in Mint
Roy_043
Post by Roy_043 »
looo wrote: Sat Feb 29, 2020 8:36 am Currently we ship libredwg with the appimage and dmg (0.19_pre).
This may need to be looked at for version V0.20. I see there is a DLL included in the Widows appimages (libredwg-0.dll), but AFAICT the import and export utility now looks for dxf2dwg.exe and dwg2dxf.exe, which are missing.
See: https://github.com/FreeCAD/FreeCAD/blob ... WG.py#L206
yorik
Founder
Post by yorik »
Roy_043 wrote: Wed Oct 20, 2021 11:20 am AFAICT the import and export utility now looks for dxf2dwg.exe and dwg2dxf.exe, which are missing.
Indeed. I don't think the dll is used anywhere else... But I seem to recall libredwg had python bindings, that we could use somehow. Beware of the license problems, though. We cannot have FreeCAD depend on libredwg
