Let's talk about libredwg support
vocx
Re: Let's talk about libredwg support
Post by vocx »
carlopav wrote: Thu Apr 02, 2020 7:31 am Yes, I am, the python dxf importer is really slow... do you think it worths working on it or you think it would be better to just have one only improved C++ one?
I think the Python importer could definitely be improved. Maybe there are some lines that make is slow, and those could be optimized. We would need to profile the code, as explained in this recent thread, Python profiling tutorial.
I like Python, so I think it makes sense to have a Python importer that is simple to test and use. Of course, if you can make a better C++ importer that would also be good. My problem is I'm not good at C++, so it would take me a while to get some progress done on that. But if you can get a C++ programmer to work on it, hey, that'd be great.
looo
Post by looo »
some little updates:
- from now on libredwg is included also in the win conda bundle
- there is still a problem with overwriting existing files which should be fixed with this commit.
Some tests show that basic import-export works with default settings (circles, arcs, lines, ellipses). Not sure about splines as I couldn't create them with draft-workbench...
vocx
Post by vocx »
looo wrote: Sat Apr 11, 2020 9:38 am ... Not sure about splines as I couldn't create them with draft-workbench...
What do you mean? There is a Draft_BSpline tool.
looo
Post by looo »
vocx wrote: Sat Apr 11, 2020 2:58 pm
After resetting the preferences splines worked again but libredwg doesn't seem to support them (or teh dxf export already doesn't support splines, I don't know)
edit: all splines of draft (interpolated bspline, bezier spline, cubic bezier) are not supported by dxf export. Therefore translation to dwg via libredwg can't work.
prokoudine
Post by prokoudine »
looo wrote: Sat Apr 11, 2020 9:38 am some little updates:
But not in the AppImage yet?
looo
Post by looo »
prokoudine wrote: Fri Aug 14, 2020 8:56 am
It should be included. Try in the python console:
import LibreDWG
But currently it doesn't work. It is difficult to tell if the problem is the dxf export or the conversation from dxf2dwg.
prokoudine
looo wrote: Fri Aug 14, 2020 9:39 am It should be included. Try in the python console:
import LibreDWG
I have FreeCAD-asm3-Conda-Py3-Qt5-20200725-glibc2.12-x86_64.AppImage
>>> import LibreDWG
ModuleNotFoundError: No module named 'LibreDWG'
Wrong AppImage file maybe? Or do I need LibreDWG installed system-wide?
looo
Post by looo »
prokoudine wrote: Sat Aug 15, 2020 10:12 pm
yes, please use 0.19 appimage (not @realthunder branch)
duncan.lithgow
Post by duncan.lithgow »
I'm working on this page about the state of DWG support in free software.
https://wiki.osarch.org/index.php?title ... wing_(DWG)
I've made some edits to https://wiki.freecadweb.org/FreeCAD_and_DWG_Import which I think the reflect the current situation. Please check I've done that correctly.
Would you agree that we need to make/describe some kind of switch between ODA converter and LibreDWG? We want to encourage use of LibreDWG be people should be able to have both available and switch between them. Is this currently possible?
Last edited by duncan.lithgow on Sun Dec 27, 2020 12:04 am, edited 2 times in total.
duncan.lithgow
looo wrote: Sat Apr 11, 2020 9:38 am - from now on libredwg is included also in the win conda bundle
OS: Windows 10 (10.0)
Version: 0.19.23323 (Git)
Hash: 512d5c6141aec52b6eecc67370336a28fde862a6
Python version: 3.8.6
Qt version: 5.12.5
OCC version: 7.4.0
Locale: Danish/Denmark (da_DK)
For me it first complained that the Teigha converter was missing (should be renamed ODA Converter or whatever). I then followed carlopavs instructions and have it working.
