Cutting a line / Problem
Edduardo
Postby Edduardo » Sun Oct 13, 2019 2:36 am
Hello everyone! I was modeling a connecting rod (with a tutorial) and when I wanted to cut one line, with the option in the sketcher workbench, the line not just don´t get erased, but change the structure of the other lines. Am I´m not using this tool correctly? :/ Thanks for reading! (:
Version: 0.17.13541 (Git)
Branch: releases/FreeCAD-0-17
Python version: 2.7.14
OCC version: 7.2.0
Locale: Spanish/Ecuador (es_EC)
Re: Cutting a line / Problem
Postby chrisb » Sun Oct 13, 2019 6:23 am
You seem to have used the Trim tool Image and this works indeed ... surprising, if the center of the circles is positioned with a point on line on the vertical line. Trimming results in an additional vertical line on top of the previous one, connected via tangency:
Snip macro screenshot-5a6517.png (2.16 KiB) Viewed 285 times
Here I have removed the tangency to show what happens:
Snip macro screenshot-d75f16.png (6.85 KiB) Viewed 285 times
Abdullah hasn't been very active recently so I think it is sensible to create a bug report in the tracker.
kisolre
Postby kisolre » Sun Oct 13, 2019 8:03 am
First prease if possible upgrade yout Freecad version at least to the latest stable - 0.18.3.
Second you should try to provide your file for examination. There are a number of ways that things can be constrained to visually display the same but which could create different results.
And finally Trim properly removes what it thinks is the central piece and leaves two end pieces. But then the solver kicks in and finds a valid solution. this might not be what you desire. So beter invoke those operations with minimally constrained sketch and when final geometry is achieved start to apply final constraints.
Here with not fully constrained sketch tool works as expected:
OS: Windows 8.1 (6.3)
Version: 0.19.18504 (Git)
Hash: f66023a646db4b2502bb3637897443b3525ca3c7
Python version: 3.6.8
Qt version: 5.12.1
Postby chrisb » Sun Oct 13, 2019 9:26 am
Before applying the tool, is the point-on-line constraint in the center double, i.e. on the x-axis and on the vertical line or only on the x-axis?
kisolre
Postby kisolre » Sun Oct 13, 2019 10:01 am
Sorry for not providing a file. Here it is with double PointOnLine constraints.
1. Create arc, center PointOnLine to X axis
2. Create nonvertical line between arc ends.
3. Constraint line vertical.
4. Constraint center of arc to line (PointOnLine)
5. create internal arc, center coincident to first arc center, endc PoinyOnLine to vertical line from point 2.
6. Trim
TrimBefore.FCStd
(5.01 KiB) Downloaded 8 times
Postby chrisb » Sun Oct 13, 2019 10:35 am
It doesn't seem to be the fully constrained sketch, it is rather the sequence of creating the elements and assigning constraints.
Trim both vertical lines in the attached sketch and they behave differently. At the right side I have clicked below the x-axis.
Snip macro screenshot-3fede8.png (11.04 KiB) Viewed 259 times
Trim_cb.FCStd
(3.77 KiB) Downloaded 9 times
